How to install NextCloud  [SOLVED]
Discussion about Docker
makhai
France
Re: How to install NextCloud
Post by makhai »
As I said, unless you have specific need you can use official supported app provided by TOS store.
I don't know nextcloud AIO but you can try a project with this conf file.
https://github.com/nextcloud/all-in-one ... mpose.yaml
For first try you can ignore all lines begin with #
Please do not modify volumes of this yml, they said so explicitly
But you can change ports like this, for avoid conflicts with TOS interface
ports:
  - 8082:8080
  - 8444:8443
SquarePeg
Wales
Post by SquarePeg »
The nextcloud version from the TNAS app store is out of date and won't let me update. When I try to use that YAML file, the project asks for a Project Path, when I put a path in, the container tries to start but fails
highgrade
Virgin Islands (USA)
Post by highgrade »
I was having alot problem I just gave up and install via windows using docker and AIO then ISCSI for from F-423. I am able to access via duckdns. This is the video I use https://youtu.be/_WsvF5Y5d2I?si=BSeL4SEdFSnHSu7x
hakest
Germany
Post by hakest »
After 3 days of trial and error I managed it to get NextCloud running:
environment:
- MYSQL_HOST=172.18.0.2:3306
application: # nextcloud app that will use the database
image: nextcloud:24
hakest
Germany
Post by hakest »
hmm
That was just one step. https is not working and the NextCloud-web-app wants now trusted domains configured.
hakest
Germany
Re: How to install NextCloud  [SOLVED]
Post by hakest »
hakest wrote: ↑09 Dec 2024, 18:55 hmm
FYI.
I tried to use the internal nginx.
First with a location config /nextcloud/ like it is done for the Portainer app. But here images, stylesheets etc. were missing in the browser. And the Nextcloud page internally used links without the additional location path element /nextcloud/ in the URL. Especially the missing location path element in the links inside the nextcloud web page I think could be difficult to manage.
Then I found the include tnasonline.conf and decided to try an additional server config with a new HTTPS port for the nextcloud container. This I managed very fast. I reused the tnas certificate here. I had to manually trust the certificate on my PC and the phone. But now I can synchronize my contacts via local LAN via HTTPS. Mission completed.
I do not want to lead somebody to a way to break his device. Therefore no further details here :)
XtinaLover
France
Post by XtinaLover »
Permet-il une utilisation transparente sur différents systèmes d'exploitation (par exemple Windows, macOS, Linux) ?
F8 SSD Plus; 6.0.610; 2 x 1024G KC3000 PCIe 4.0 SSD;
:idea: Dans l'ocean des données, le stockage est mon bateau.
Return to “Docker”
