TOS 5.1.131 (X86) is Released for Update
DigitalAnalog
Australia
Re: TOS 5.1.131 (X86) is Released for Update
Post by DigitalAnalog »
Data scrubbing on btrfs TRAID volumes doesn't work on .131. It's crazy that TOS's flagship RAID configuration and recommended filesystem (btrfs) doesn't support one of the key tools for protecting and maintaining data integrity.
Also, I secure wiped my drives only to find after re-installing TOS that all the data was still there. Incredible.
F4-423
IrisLi
Post by IrisLi »
crisisacting wrote: ↑19 May 2024, 07:31
May I ask if there are any other processes occupying the volume when configuring SSD? You can check through the following link:
viewtopic.php?t=5955
May I ask if compatibility issues have been checked? Compatibility list:
https://www.terra-master.com/global/compatibility/
crisisacting
Post by crisisacting »
TMqiky wrote: ↑19 May 2024, 15:41 May I ask if compatibility issues have been checked? Compatibility list:
It's compatible; the drive was used as the SSD cache on TOS 4.× builds; it was secure erased prior to trying to add it & has been repeatedly between attempts to add Hypercache .
Haven't been able to get any TOS 5.1.1×× builds to add a cache since doing a clean install.
Have already been getting complaints about delayed read.
brunix86
Italy
Post by brunix86 »
TMRyan wrote: ↑07 May 2024, 10:37
Hi, after this update (from version 5.1.123) I noticed that port 80 (and also 443) is always used by process "nasips".
Before the update I used WebServer with port 80 and it worked fine.
Could you kindly check if something is changed and how I can use port 80 in WebServer?
I need to use this specific port to do the "SSL certificate renew challenge" from Let's Encrypt.
I already tried to reboot NAS but I have the same problem.
Thanks!
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.1278 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
brunix86 wrote: ↑01 Jun 2024, 17:09
We will verify this.
You can open Control Panel - Network - General again and release port 80/443. Then you can use it for your WebServer.
brunix86
Italy
Post by brunix86 »
TMzethar wrote: ↑01 Jun 2024, 18:41
Hi, using the option you mentioned "Release ports 80 and 443" worked fine!
But I'm sure that the option was already checked before update to 5.1.131.
I think the update unchecked\disabled the option.
Thanks!
My NAS Environment
  • TNAS F4-424
After this: viewtopic.php?t=6232 (Post power fail re-install)
Email Notifications failed and needed to be reset.
zonatar
Italy
Post by zonatar »
Is there any guide to update from 5.1.131 to TOS6?
viewtopic.php?p=36580#p36580
Read ALL the notes first, since I don't know what model you have and what your start point was.
TMeric
Post by TMeric »
zonatar wrote: ↑13 Nov 2024, 02:38 Is there any guide to update from 5.1.131 to TOS6?
You can refer to the upgrade path in the following link to upgrade your TOS.
viewtopic.php?t=6984
