Trying to remote mount SMB folder
Re: Trying to remote mount SMB folder
Just a thought == Samba Version mis-match
Frustrated Beta Tester!!!
First, use putty to enter the terminal:DigitalAnalog wrote: ↑05 Apr 2024, 11:12 I've isolated the problem as a potential SMB incompatibility between my ASUS AX88U router and the F4-423, as I was able to remote mount another SMB share from another device on the network within the NAS.
Am I able to extract logs about how the SMB connection fails? The "remote source path unavailable" error message is not very helpful and is not even mentioned in TerraMaster documentation.
The issue persists on both the stock ASUS and Asuswrt-Merlin firmwares. Thank you.
viewtopic.php?t=2350
Enter the following command to view SMB logs:
cat /var/log/samba/log.smbdTo contact our team, please send email to following addresses, remember to replace (at) with @
- Captain8836
I am having the same issue how was this resolved?
I have a F2-223, I am able to create rsync backup and schedule the backup and it works perfect.
But I am not able to create a remote folder I receive the message "remote source path unavailable" same as above user.
Thank You
Thank You
did you get this resolved I also have the same problem I cant get it to connect to my wdcloud nas this is stupid such a simple thing but my router is a archerTMqiky wrote: ↑05 Apr 2024, 16:52First, use putty to enter the terminal:DigitalAnalog wrote: ↑05 Apr 2024, 11:12 I've isolated the problem as a potential SMB incompatibility between my ASUS AX88U router and the F4-423, as I was able to remote mount another SMB share from another device on the network within the NAS.
Enter the following command to view SMB logs:Code: Select all
- DigitalAnalog
No - I have not heard of a resolution yet.
TM reps - any update on this please? It looks like I'm not the only with this issue, and I'm sure there are others too. This is a basic function that should be standard on a NAS.
F4-423
Both NAS and routers may have customized root file systems, and the mounting points for file directories may also differ. You should consult their respective vendors rather than us, as we do not know the full mounting paths for these routers and NAS devices. Their directories are not necessarily mounted under the root directory.
- DigitalAnalog
I have zero problems mounting this shared folder from my Mac, from my PC, from my phone, from my Android TV, literally no other device has this mounting issue issue except the TNAS.TMroy wrote: ↑09 May 2024, 11:41 Both NAS and routers may have customized root file systems, and the mounting points for file directories may also differ. You should consult their respective vendors rather than us, as we do not know the full mounting paths for these routers and NAS devices. Their directories are not necessarily mounted under the root directory.
Now you have other people going forward with the same issue with different devices where the only common thing is Terramaster - and yet somehow the issue is with all these other devices??
F4-423
Once again:
We have verified in our lab that the SMB mounting function on the TOS web page works normally, and we have successfully mounted directories from a Synology NAS and Ubuntu server. Please confirm if your mounting path is correct, and also ensure that the correct SMB version is enabled on the target device you are trying to mount. It is recommended that the SMB versions on both sides remain consistent.
Do you want to mount the device with the same IP and LAN gateway as 192.168.50.1?DigitalAnalog wrote: ↑09 May 2024, 15:17I have zero problems mounting this shared folder from my Mac, from my PC, from my phone, from my Android TV, literally no other device has this mounting issue issue except the TNAS.TMroy wrote: ↑09 May 2024, 11:41 Both NAS and routers may have customized root file systems, and the mounting points for file directories may also differ. You should consult their respective vendors rather than us, as we do not know the full mounting paths for these routers and NAS devices. Their directories are not necessarily mounted under the root directory.
Well, I did manage to get past the "unavailable" result. But, now I just have a 'spinning circle' while nas tries to mount the folder. Maybe your developers should try getting out of the 'lab' into the real world. I have noticed the continued reference to the IP (and now gateway) addresses. I am working on a LAN where the shared folder is on the LAN. The 'server' is a windows 10 machine with a machine name. I use SMB3. IP addresses for the 'server' are DHCP assigned. The share is visible on the network. I use passwords with special characters. I use a username which is an email address (Microsoft account). 15 minutes later it just sits there looking miserableTMroy wrote: ↑09 May 2024, 17:05 Once again:
I have ensured that all names etc are of the correct case. All this is being done with the NAS admin account and a windows admin user. Any (useful) suggestions?
