TOS 5.1.95 (X86) is Released for Update
Alessio71
Italy
Re: TOS 5.1.95 (X86) is Released for Update
Post by Alessio71 »
Gremlin wrote: ↑18 Nov 2023, 07:16 Just updated to 5.1.95 on F2-221. Skipped .79. No issues with date format.
Confirm, no date issue anymore
topo01
Germany
Post by topo01 »
Not good!
In TOS 5.1.67 it didn't recognise the new updates so I had to manually update to 5.1.95.
After reboot I got a white screen "Loading.... Please wait" for more than 6 hours!
Can please someone tell me what the system was doing during that time? It really worried me an there was no other message.
Then I updated Docker from 1.2.8 to 1.2.9 which made it disappear from the desktop. Strangely it took another hour or so until the "Send to desktop" button re-appeared...
F2-220, OMV 7.5, Docker (Nextcloud, AdGuard Home, immich, File Browser, Stirling PDF)
joka388
Austria
Post by joka388 »
Clean install on F2-221 an the SMB Speed still drops to 21 Mb/s :evil:
No Problems with 4.2.40, i dont understand why.
That's it for me with TerraMaster :evil:
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
{L_BUTTON_AT}joka388
Have you tried disabling scheduled power on/off?
Frustrated Beta Tester!!!
{L_BUTTON_AT}topo01
If you have a large number of files, it is likely due to automatic detection and repair of the file system. It cannot be ruled out that there may be other influential anomalies. But it should be unrelated to the update. Will you still encounter this situation after restarting TNAS?
joka388
Austria
Post by joka388 »
Gremlin wrote: ↑23 Nov 2023, 17:15 Have you tried disabling scheduled power on/off?
If no start times are selected after the initial installation, the SMB speed is normal at 113 Mb/s. But as soon as the start times have been selected, switching them off no longer helps - the SMB speed remains at 21 Mb/s
joka388 wrote: ↑23 Nov 2023, 21:16
Delete schedules as well. (This worked on earlier versions. I found I did not need to do this on later, but you never know). @TMsupport = apparently still an issue.
topo01
Germany
Post by topo01 »
{L_BUTTON_AT}TMzethar
Yes, after the second restart it also took about an hour before I could log in.
I have a fairly fresh setup as I did a clean install just in July based on 5.1.41 (with 8GB system partition). I'm mainly running a few shares and Docker/Nextcloud for some syncing. Only recently I installed Terra Photos and activated media scanning. My 2TB RAID is only 33% filled, mostly with photos.
joka388
Austria
Post by joka388 »
Gremlin wrote: ↑23 Nov 2023, 21:23
Thx for the TIP, it works. Deleting of the schedules than restart an the SMB Speed ist at 113 Mb/s.
Very strange :o :evil:
We will verify the issue you mentioned.
