Docker Compose missing dependancy?
TMnorah
Re: Docker Compose missing dependancy?
Post by TMnorah »
We are handling and troubleshooting this issue, please wait patiently.
XFNeo
Post by XFNeo »
TMnorah wrote: ↑13 Nov 2022, 16:19 We are handling and troubleshooting this issue, please wait patiently.
I guess the issue with docker-compose has been fixed in the latest version?
{L_BUTTON_AT}XFNeo
If you still can't solve the issue according to the methods we provide, please contact our tech team check it remotely.
TASzser
Post by TASzser »
Hey :wave:,
I am having problems running docker compose. I get this error message.
[user@TNAS-3771 ~]# docker-compose
Traceback (most recent call last):
File "/Volume1/@apps/docker/dockerd/bin/docker-compose", line 33, in <module>
sys.exit(load_entry_point('docker-compose==1.24.1', 'console_scripts', 'docker-compose')())
File "/Volume1/@apps/docker/dockerd/bin/docker-compose", line 22, in importlib_load_entry_point
for entry_point in distribution(dist_name).entry_points
File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 957, in distribution
return Distribution.from_name(distribution_name)
File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 548, in from_name
raise PackageNotFoundError(name)
importlib.metadata.PackageNotFoundError: No package metadata was found for docker-compose
{L_BUTTON_AT}TASzser
Hi, :wave: Please provide your TNAS model and TOS version, as well as the version of the Docker app. What operation did you prompt this message after? Can you provide the previous operation information and relevant screenshots? The question you raised is not related to the theme. We suggest that you open a new theme post separately.
Return to “System Update”
