TOS 5.0.171 (x.86) is Released for Update
calamariring
Re: TOS 5.0.171 (x.86) is Released for Update
Post by calamariring »
TMwuu wrote:
> [quote=quella post_id=21655 time=1665000864 user_id=5421]
> Just a heads up on something I have noticed with this the TOS 5.0 version
> that seems like a bug.
> I noticed that if I login to the web GUI as the Admin (have not tried other
> users) and I open the "System Info" tray in the top right of the
> screen; by the Notifications. If I leave this up and go to other tabs or
> other windows on the computer, the System Time of the system begins to lag
> by a few minutes and sometimes more than two hours depending how long I
> leave that tray item open.
> If I open up the "control panel" and select to re-sync to the
> configured NTP server (default time server) my time is back to being
> correct. However, if I repeat the same steps above, my time will drift
> again.
> It would be best if the system could sync with an NTP server at a set day
> or time interval to ensure it is in sync. Or correct the issue of time
> drifting if this system tray is left open for an extended period. I'm
> currently monitoring the Indexing routine and watching CPU/Memory
> Computer: MacOS
> Browser: Chrome (latest)
> TOS: 5.0.171
> Replaceable: Yes
> [/quote]
> Hello, our laboratory did not reproduce the problems you encountered. Can
> you provide some screenshots? It is recommended that you clear the browser
> cache and refresh the browser page for an interview.
I can replicate this issue.
I am using MacOS, Firebox browser, and TOS 5.0.171.
You can see my video here : https://youtu.be/pNGLws9QZ3s
At the start, I sync NTP.
Left the window open and recording. Compare the TOS lock with my Laptop clock on the top right corner.
After a few minutes, there is 1 second difference.
After about 8 minutes, there is 2 second difference.
{L_BUTTON_AT}calamariring
Please try to refresh the web page and check if the time is correct after refresh.
zedmel
Post by zedmel »
Memory module,
I've just use an 4go old laptop memory module on my F2-220 for year, It works great.
Just try, your NAS boots on, that's great.
It doesn't too bad put back the module you've.
Roccia7
Italy
Post by Roccia7 »
zedmel wrote:
> Memory module,
> works great.
Do you remember wich is the memory? The manufactor?
scavenger_ro
Post by scavenger_ro »
https://nascompares.com/ram/terramaster ... m-upgrade/
2 extra options beside what I gave you are on the above page.
That should work for you IF they didn't used the machine as a testbed for what they're doing now with the 223/423 series.
zedmel
Post by zedmel »
to Roccia7
I don't remember sorry the brand /manufactor.
Just pick it up form an old Dell laptop
calamariring
TMroy wrote: > > > Please try to refresh the web page and check if the time is correct after > refresh. Ok, so I logged in and left the display running overnight from yesterday. When I opened my laptop, this is what I saw it says the time is 28:15:06 https://www.dropbox.com/s/ypnrftba19rl5 ... 6.png?dl=0 But after refresh the page, the clock is correct but behind my laptop clock by 2 seconds. (I last sync NTP 3 days ago on TOS) Still, it is suggested an option to allow the device to sync the NTP every 24 hours or some options that we can set. Please consider this a feature request. Thank you.
scout71
Italy
Post by scout71 »
After the reboot, everything is fine for a day, then the "mediaindex" process goes back to above 55% constantly ... and of course I have constant signs of a slow system. This even if I don't do anything with the NAS.
crisisacting
Post by crisisacting »
Is a TOS patch or new build coming this week?
Asking since NAS warned about the tnas.link certificate being set to expire on October 16th 2022.
kenfrog
Post by kenfrog »
Noticed a problem - I was trying to add a SMB user
I was connected to the NAS added a new user named : SomethingCool gave a password and permissions to the folders and groups. saved and the system took the user, checked the folder and group permissions should allow the user to login and use SMB
could not connect - no known user is the error from Apple Finder.
Toggled SMB and AFP, no luck, applied permissions recursively, enabled and disabled user and changed the password three times.
thinking that Apple is the cause here and not the NAT - doinked about the settings and found no reason that my system cant connect.
enabled and disabled SMB,AFP and no change
I'm on a MacMini trying to access the nas using SMB or AFP - nothing worked.
FIx : selected a user created a while back - worked fine ???
SO, tested the new user and still nothing - removed the new user and used the known old account and SMB or AFP work
Guessing that the new users dont really get access until reboot ? I don't need a second user now so i removed the new user and elected to use the old one. :)
Figured that someone will run into this same issue
