TOS 4.2.30 is released for update!
Re: TOS 4.2.30 is released for update!
Hi guys,
Normal online update hangs at Unzipping files stage and eventually loggs out from the console.
I am updating from TOS 4.2.08 to 4.2.30.
Tried this 3 times and still no luck.
Any thoughts?
Any thoughts?
Emby is not compatible with TOS 4.2.30 and will be updated as soon as possible.
Saijin_Naib wrote: ↑02 Mar 2022, 01:34 Please post the manual download files immediately.
Online update is not working.
Terramaster Download Center
Please try to update to TOS 4.2.18 manually first, then update to TOS 4.2.30.
- Saijin_Naib
{L_BUTTON_AT}TMSupport
- Charlie_Croker
Updated from .28 to .30 on F2-422 with no issues.
- snapperheadjoeTM
I updated to 4.2.30 this morning and am getting the following error when clicking on any notification link in the panel. Clicking the link normally takes you directly to that module in Control Panel to view the component referenced in the notification. Now anytime I click the notification link I get the error below. I can still navigate manually to the component and interact with it but the links are all broken from the notification panel.
Fatal error: Uncaught Error: Call to undefined function htmlspecial() in /usr/www/mod/1.Control/4.SysManage/2.hardset.php:5 Stack trace: #0 {main} thrown in /usr/www/mod/1.Control/4.SysManage/2.hardset.php on line 5
- snapperheadjoeTM
Another issue I've noticed with these updates is that the SMTP notifications configuration gets wiped everytime you update the firmware. It happened when I updated to 4.2.28 and 4.2.30. It doesn't take long to add them back in but if you forget to do it you won't get email notifications till you configure it again. Please fix this for the next update.
{L_BUTTON_AT}snapperheadjoeTM
I tried to update twice online to 4.2.30 and it is still the old version.
Should I try and do the offline method?
