TOS 4.2.30 is released for update!
For data security, be sure to update your TOS system!
TOS 4.2.30 (ARM) Release Notes
Applicable models: F2-210, F4-210.
1. Fixed a security vulnerability related to the Deadbolt ransomware attack.
TOS 4.2.30 (X86) Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422
2. Optimized fan control during HDD hibernation.
Important Notes
1. This update is only for TOS 4.2.01 or later versions. If your TOS is 4.1.27 or an earlier version, please refer to here.
3. If you are running VirtualBox in TOS, please update the VirtualBbox before updating 4.2.30, otherwise, your system will fail irreparably!
VirtualBox download link
4.TOS 4.2.30 needs to be used with the new version of the TNAS Mobile APP, the version of TNAS Mobile for android is 2.4.18, and the version of TNAS Mobile for iOS is 2.4.13.
How to update your TOS?
Online update:
1. Go to TOS > Control Panel > General settings > Software update;
2. Check the option "Online update", click "Apply";
3. Follow the prompt to finish the update;
Manual update:
1. Download the update package: Update package for ARM models; Update package for x.86 models
2. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Manual Update”;
3. Click "Browse" to select the update package;
4. Click "Apply";
Issue report
If you encounter issue during using, please report to TerraMaster official forum “TOS update”.
crisisacting
Re: TOS 4.2.30 is released for update!
Post by crisisacting »
This includes the recent 1.31 TOS patch as well?
Why does each changelog always neglect to mention the patches?
crisisacting wrote: 01 Mar 2022, 20:13 This includes the recent 1.31 TOS patch as well?
The patch 1.31 has been included in the TOS 4.2.30.
V8Triker
Post by V8Triker »
Just saw the update, and have applied it.
Remember to leave a few minutes before trying to login, otherwise you will loop on the login screen and think there is an issue.
And yes, Plex is still working ;)
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
Jac de Lad
Post by Jac de Lad »
Does this help against the current attack wave?
Gandalf1369
Post by Gandalf1369 »
Since this version TOS version is not yet available for download from the Terra-Master website, how about a download link here so users who want to manually update can . . .
sports_wook
Post by sports_wook »
The check for updates isn't working for me, been trying for the past couple of hours. Would also appreciate a download link for manual update.
gretor
Post by gretor »
Update has worked so far. One note : For me it reset the SMB setting in the menu to factory and I had to reset the SMB things like smb 2 minimum to smb 3 maximum!
Some other security settings like the DDOS protection were also disabled after the update !
lg gretor
TNAS F2-221 - TOS 5
4 GB Ram
2x 4 TB WD Red - Raid 1
{L_BUTTON_AT}crisisacting
Just imagine, if the new update excludes the past patches, it is very illogical.
{L_BUTTON_AT}"Jac
yes, it is.
