[ ZeroTier ] Securely connect any device, anywhere
Re: [ ZeroTier ][ 1.8.9.0 ] Securely connect any device, anywhere
is it because google drive is blocked in your country, or any other issue ?
Just to understand the situation.
wayneeden
Post by wayneeden »
{L_BUTTON_AT}outkastm
i'd fixed download from google
but when i updated 1.8.9.0,i found "Config files are stored to /mnt/appdata/MOD_CONFIG/ZeroTier" is empty
i couldn't use "sudo zerotier-cli join xxxx"
pls help
download again and install the app, i made some changes
Re: [ ZeroTier ][ 1.8.10.0 ] Securely connect any device, anywhere
up to 1.8.10.0
Re: [ ZeroTier ][ 1.10.0.0 ] Securely connect any device, anywhere
up to 1.10.0.0
Re: [ ZeroTier ][ 1.10.1.0 ] Securely connect any device, anywhere
up to 1.10.1.0 and added TOS5 support
mts33
Post by mts33 »
Please help
I got 500 error
root@TNAS:/# sudo zerotier-cli join xxxxxxxxxxxxxxxx
500 join {}
root@TNAS:/# sudo -i zerotier-cli listnetworks
Welcome to TNAS
200 listnetworks <nwid> <name> <mac> <status> <type> <dev> <ZT assigned ips>
root@TNAS:/#
user222333
Post by user222333 »
Please help
can't connect to network TOS version 5.0.176-00227
["first created acount"@TNAS-627A ~]# sudo zerotier -cli join "NETWORK ID"
sudo: unknown user: root
sudo: unable to initialize policy plugin
UserGuide say:
If your TOS version is TOS 5, please use your first created acount to log in SSH terminal.
(The user created for the first time is the super administrator, and there is no root user in TOS 5.)
arqweryon
Post by arqweryon »
Don´t use sudo. Just use the command:
user222333
{L_BUTTON_AT}arqweryon
Thanks, It works!
