[ KernelModules ] Kernel module USB drivers
Re: [ KernelModules ] Kernel module USB drivers
There is no release note
XFNeo
Post by XFNeo »
{L_BUTTON_AT}outkastm
Something strange, bluetooth module is not loaded, but cdc_acm is loaded (I have reboot my TNAS after updating version and enabling all modules)
[root@TNAS-xxx ~]# lsusb -vt
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 10000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/8p, 480M
    |__ Port 1: Dev 2, If 1, Class=, Driver=cdc_acm, 12M
    |__ Port 1: Dev 2, If 0, Class=, Driver=cdc_acm, 12M
    |__ Port 2: Dev 3, If 0, Class=, Driver=, 12M
    |__ Port 2: Dev 3, If 1, Class=, Driver=, 12M
    |__ Port 5: Dev 4, If 0, Class=, Driver=usb-storage, 480M
btusb driver set to be loaded: reconnect device or reboot NAS
btbcm driver set to be loaded: reconnect device or reboot NAS
btintel driver set to be loaded: reconnect device or reboot NAS
btrtl driver set to be loaded: reconnect device or reboot NAS
usblp driver set to be loaded: reconnect device or reboot NAS
cdc-acm driver set to be loaded: reconnect device or reboot NAS
usbserial driver set to be loaded: reconnect device or reboot NAS
ch341 driver set to be loaded: reconnect device or reboot NAS
cp210x driver set to be loaded: reconnect device or reboot NAS
pl2303 driver set to be loaded: reconnect device or reboot NAS
ftdi_sio driver set to be loaded: reconnect device or reboot NAS
f81232 driver set to be loaded: reconnect device or reboot NAS
f81534 driver set to be loaded: reconnect device or reboot NAS
garmin_gps driver set to be loaded: reconnect device or reboot NAS
ipw driver set to be loaded: reconnect device or reboot NAS
ir-usb driver set to be loaded: reconnect device or reboot NAS
mxuport driver set to be loaded: reconnect device or reboot NAS
navman driver set to be loaded: reconnect device or reboot NAS
option driver set to be loaded: reconnect device or reboot NAS
oti6858 driver set to be loaded: reconnect device or reboot NAS
qcserial driver set to be loaded: reconnect device or reboot NAS
sierra driver set to be loaded: reconnect device or reboot NAS
spcp8x5 driver set to be loaded: reconnect device or reboot NAS
symbolserial driver set to be loaded: reconnect device or reboot NAS
ti_usb_3410_5052 driver set to be loaded: reconnect device or reboot NAS
usb_debug driver set to be loaded: reconnect device or reboot NAS
usb-serial-simple driver set to be loaded: reconnect device or reboot NAS
usb_wwan driver set to be loaded: reconnect device or reboot NAS
sorry i have no bluetooth dongle to test further.
XFNeo
Post by XFNeo »
Bad news(
Mb I can test it?
Vaoske
Post by Vaoske »
Hi again,
When using the updated kernelmodules no "connection" with the device is possible. Is there anything I'm dong wrong?
Greets
Bus 001 Device 018: ID 0403:6001
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0403
  idProduct          0x6001
  bcdDevice            6.00
  iManufacturer           1 FTDI
  iProduct                2 FT232R USB UART
  iSerial                 3 AC2EZ4E0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               90mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255
      bInterfaceSubClass    255
      bInterfaceProtocol    255
      iInterface              2 FT232R USB UART
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
Device Status:     0x0000
  (Bus Powered)
[remkofaes@TNAS-5DA3 ~]# ls -l /dev/serial/by-id
total 0
lrwxrwxrwx 1 remkofaes remkofaes 13 May  4 17:17 usb-FTDI_FT232R_USB_UART_AC2EZ4E0-if00-port0 -> ../../ttyUSB0
[remkofaes@TNAS-5DA3 ~]#  ls -l /dev/ttyUSB0
crw-rw---- 1 remkofaes dialout 188, 0 May  4 17:17 /dev/ttyUSB0
the user which need to connect to FTDI adapter must be part of the dialout group.
As example for homeassistant user
usermod -a -G dialout homeassistant
[user@TNAS-xxx ~]# cat /etc/group | grep dialout
dialout:x:18:homeassistant
restart the app or log out / log in
Vaoske
Post by Vaoske »
It’s working!!!! Thanks
XFNeo
Post by XFNeo »
outkastm wrote: 04 May 2023, 04:19 sorry i have no bluetooth dongle to test further.
Mb I can test it? What should I do?
updated (fixed the bluetooth driver load)
XFNeo
Post by XFNeo »
outkastm wrote: 23 May 2023, 07:10 updated (fixed the bluetooth driver load)
Hi! Now I see driver in lsusb
# lsusb -vt
    |__ Port 2: Dev 3, If 0, Class=, Driver=btusb, 12M
    |__ Port 2: Dev 3, If 1, Class=, Driver=btusb, 12M
But does not see tty interface and /dev/serial/by-id/ link for it.
