[ Jellyfin ] The Free Software Media System
Re: [ Jellyfin ][ 10.7.7.0 ] The Free Software Media System
updated to 10.7.7.0
scout71
Italy
Post by scout71 »
Hi, I tried to install Emby and everything worked great. I then tried to install Jellyfin and it doesn't recognize the covers, I checked the router and the port seems configured fine ... I also enabled automatic port mapping. What could I check again? It does not access outside my network.
Download again the latest Jellyfin version, i made a small update
Make sure you have also the latest version of ModBase1 app installed
Re: [ Jellyfin ][ 10.7.5.0 ] The Free Software Media System
betuning wrote: 30 Jun 2021, 15:30
outkastm wrote: 29 Jun 2021, 22:19 Check the log file after you press the identify
[2021-06-30 09:29:04.378 +02:00] [ERR] [18] MediaBrowser.Providers.Manager.ProviderManager: Provider "The Open Movie Database" failed to retrieve search results
System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: PartialChain
at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception)
at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm)
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Boolean async, Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)
--- End of inner exception stack trace ---
at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.GetHttpConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.SendAsyncCore(HttpRequestMessage request, HttpCompletionOption completionOption, Boolean async, Boolean emitTelemetryStartStop, CancellationToken cancellationToken)
at MediaBrowser.Providers.Plugins.Omdb.OmdbItemProvider.GetSearchResultsInternal(ItemLookupInfo searchInfo, String type, Boolean isSearch, CancellationToken cancellationToken)
at MediaBrowser.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken)
at MediaBrowser.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken)
try version 10.7.7.0, this issues should be solved now
scout71
Italy
Post by scout71 »
outkastm wrote: 03 Oct 2021, 06:57 Download again the latest Jellyfin version, i made a small update
Thank you very much, now everything works! You are a wizard!
scout71
Italy
Post by scout71 »
Today I had the bad idea of ​​updating the system ... I discovered that when I go to see a movie the player gives an error. i tried reinstalling ffmpeg and modbase1 but it didn't work... keeps giving the player error... everything else works :cry:
I've checked here on latest 4.2.16 TOS x86 an no issue so far (testing in webplayer). New TOS update should not affect the 3rd party apps.
Can you check the log files maybe to identify what goes wrong after you try to play the movie ? Can you also try to play the movie directly in Web
Logs can be checked here
http://yourNASip:8096/web/index.html#!/log.html
scout71
Italy
Post by scout71 »
Thanks for the tip! I checked the log file and I realized that in fact, I don't know why, but after the update the system changed the name of my usb disks ... in practice jellyfin could not find the files anymore! I had to put all the libraries back but now it works! I will remember to check the logs next time !!!
glad it works
scout71
Italy
Post by scout71 »
This time I ask before updating ... are there any problems with the latest version 4.2.17? I wouldn't want to have a problem with Jellifyn right now that I'm enjoying it
