TOS 7 ARM Official Release Announcement
Arktander
Re: TOS 7 ARM Official Release Announcement
Post by Arktander »
I had no problems updating from TOS 5.1.73 to TOS 7.0.1113, which is running very well right now, but I am having no success upgrading from TOS 7.0.1113 to the latest TOS 7.0.1114 update. The upgrading process had a run up to 86% and then just exited to the error message. Any idea what's happening?
Flyingbike wrote: 30 Aug 2026, 00:57
Thank you for your feedback. We are aware of this issue, and our product team is currently working on plans to improve it. We will keep you updated as soon as there is any further progress.
Arktander wrote: 30 Aug 2026, 06:44
TOS 7.0.1113 and 7.0.1114 are actually the same TOS 7 official release, with different version numbers used for different upgrade scenarios.
TOS 7.0.1113 (ARM) is the official release intended for devices currently running TOS 7.0.1078 Beta or later, allowing Beta users to upgrade to the official version.
TOS 7 ARM official release 7.0.1114 is intended for devices running TOS 5.1.73 or later, including users currently running TOS 6 Beta.
tetrapack15
Italy
Post by tetrapack15 »
after uploadding the TOS_ARM2.0_Update_7.0.1114_1614_2607291227.bz2 file. nothing happens. the buffer bar goes 99%, than the system continue to work correctly without software updare
my system is a F2-212 ARM based, running TOS 5.1.73
tetrapack15 wrote: 30 Aug 2026, 18:37 after uploadding the TOS_ARM2.0_Update_7.0.1114_1614_2607291227.bz2 file. nothing happens. the buffer bar goes 99%, than the system continue to work correctly without software updare
Please try clearing your browser cache, or use your browser's incognito/private mode to log in again.
If the same issue persists, please locate the relevant upgrade logs in the homes directory in File Manager, and send the logs to our technical support email at [support(at)terra-master.com]. Once we receive them, we will further analyze the logs and troubleshoot the issue.
Jragg
France
Post by Jragg »
I tried upgrading from version 5.1.73 but now my F2-212 won't start.
I tried removing the disk but still nothing. I can hear the fan starting to spin for three seconds then stopping then restarting and stopping and so on.
So my NAS seems bricked, is there anyway that I can recover it ?
I saw there was a way with an usb key for f2-210 but it doesn't seems to work for F2-212.
Thanks in advance, Thomas
Jragg wrote: 31 Aug 2026, 00:55
When booting with all hard drives removed, can you hear a beep? Based on your description, this may be a power supply issue — is the power adapter working properly? If you have a power adapter with a similar wattage, you can swap it in to test. You can also record a startup video and send it to our technical support email [support(at)terra-master.com]for confirmation.
Jragg
France
Post by Jragg »
No beep, the front status led is lighting up for 3 seconds then shuts down for 1 second and geins agains like the fan. I tried with another power adpater with the same wattage and it does exactly the same.
Jragg wrote: 31 Aug 2026, 14:16
Based on your description, this may be related to the motherboard's power supply. Please record a startup video and send it to our technical support email [support(at)terra-master.com] for confirmation. Please also include the link to this post in the body of the email.
Jragg
France
Post by Jragg »
CursaYang wrote: 31 Aug 2026, 15:09
Thank you the mail has been sent.
