TOS 7.0.0777 Official Release (X86) is Now Available
EriChan
Re: TOS 7.0.0777 Official Release (X86) is Now Available
Post by EriChan »
Andy2026 wrote: 08 Jul 2026, 14:55
Thank you for your feedback.We will continue to monitor the situation and attempt to reproduce the issue you mentioned.
chlor12
Germany
Post by chlor12 »
Is there a manual download for this update?
It seems that there is always someone who wants to know if there is a manual download for a new release.
How to create a manual download for a new release (Tongue firmly in cheek :) )
Go to Control Panel > System > Update
You will see the advice of a new release.
'Click' Download (NOT Download and update!)
This will download the new release to a default folder in Volume1.
Open Terminal as the admin super-user:
cd ~
cp /Volume1/.update*/*.* .
This will copy the update .bz2 file to the admin super-user home folder. (~ == tilde short-cut)
You can then re-copy that .bz2 file to a local computer (or anywhere else you care to.)
I try to do this every time I see a new release (except for those I believe are "broken") so
1. I have the historical record.
2. It makes it slightly easier to do off-line updates on multiple machines.
Please do not ask me for copies.
F5-221 TOS7.0.1188 - 4x4TB (Ironwolf) Traid
F2-424 TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid
F2-221 TOS7.0.1188 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
chlor12
Germany
Post by chlor12 »
"Is there a manual download for this update?"
Sorry
This Terramaster F8 SSD Plus is connected to an internal network and is not connected to the Internet.
joka388
Austria
Post by joka388 »
jayjay wrote: 08 Jul 2026, 04:19 I'm still seeing problems with HDD drives not going into sleep mode, does anyone else have the same problem?
same here, no sleep mode on both NAS F2-221 and F4-425
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
Metrogeek
Post by Metrogeek »
F4-425 Plus
Still having docker manager issue with this version. At Nas startup it works fine but few hour later if i want to open docker manager, it ask me to enable, if i click enable it takes long time (3-4 minutes) before the button change to open
FredMutter
France
Post by FredMutter »
Metrogeek wrote: 08 Jul 2026, 23:12 F4-425 Plus
I think I have the same problem :-) However, I’ve found a solution to the long-standing issue. I close the browser tab for the TOS 7 Desktop and open a new one immediately. Therefore, I believe it’s more of a display/refresh problem than a real bug.
Metrogeek
Post by Metrogeek »
FredMutter wrote: 09 Jul 2026, 00:02
You're right! I check in terminal and docker showed as running and active. Did the close and open a new tab fixed the issue.
Thks
jayjay
Niger
Post by jayjay »
CursaYang wrote: 08 Jul 2026, 08:21
In this version, we fixed the system disk hibernation function. Is the hard drive you mentioned that cannot hibernate the system disk?
No, a hard drive that doesn't go into sleep mode isn't a system drive. The system runs on a completely separate NVMe drive. Hard drives are used solely for data storage and are not currently being used by anything.
jayjay wrote: 09 Jul 2026, 00:37
You may need to consider the practicalities of what you system is doing. I have one nas with the system disk on nvme (along with Volume1) and I can assure you that the hdd do go into sleep mode (if I select that mode) BUT as soon as I access the web GUI the hdd will start up - I have very old, noisy drives and it can be quite spectacular in a dark quiet room! On the other hand I have systems with remote drives connected and you can never be sure when they might start. Another scenario is I have cctv cameras sending images over FTP every few seconds - those hdd don't sleep (and they should possibly be replaced with cctv spec drives).
