Please check in app center if your apps are installed to Volume1, replace Volume1 in the command line to the Volume for apps installed to then run command line again.
TOS 7.0.0616 Beta (X86) is Released for Update
Re: Request to completely remove stuck menu shortcuts for OpenClaw and Jellyfin (TOS 7 Beta Feedback - @weerasak)
Re: TOS 7.0.0616 Beta (X86) is Released for Update
Both F5-221 and F2-221 upgraded to TOS7.0.0616 without any issues.
To my surprise the time expected for a move or copy is calculated again. Thanks.
F5-221 - TOS7.0.1536 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.1536 - 2x3TB JBOD - 1x4TB Single USB
Hi, on my F2-221 I keep getting the error message that the package cannot be unpacked and that I should try again later.
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
Thank you for your feedback. Please enable debug mode in Support and Help, and then upgrade again. If the upgrade still fails, please generate debug logs and send them to our email address: support(at)terra-master.com
The lack of space might explain why the update cannot be unpacked. Are you able to free up some space or add capacity?
Frustrated Beta Tester!!!
Hi, I freed up storage space, but it still didn't work. As soon as I clicked "Download and Install," an error message appeared after the download saying the file couldn't be extracted. However, if I downloaded the file first and then clicked "Update," it worked.
On the F4-425, it worked immediately via "Download and Install."
Interesting. I have not seen this issue and the only basic difference between our -221 devices is I have 10GB Ram installed
Have you enabled quota functionality? This is a known issue, and we are discussing how to optimize it. Currently, the only options are to wait for the process to finish or increase memory.
