The Brand New TOS 5 is Released!
OllieHardy
Re: The Brand New TOS 5 is Released!
Post by OllieHardy »
After today's update I can confirm, that tnas online still doesn't recognise my NAS, despite changing the server from global to China to Europe etc. What is happening with this rollout?
Roccia7
Italy
Post by Roccia7 »
Hello
I'm trying to make media index but it always stops at 4942 files. It has been like this for at least 3 latest versions of tos5. I have tos 5.0.126, boot version 5.6.5 and f-220. Is there somethimg that can i do or is it a bug?
{L_BUTTON_AT}Roccia7
Please provide logs so we can analyze the reason. 1. Login to the SSH terminal. 2. Execute the command below.
cat /var/log/media.log
cat /var/log/mediadb/mediadb.log
{L_BUTTON_AT}OllieHardy
Please try to re-enable TNAS.online and select Global.
Check whether the ID status is successfully registered.
If you still can't access it, can you send us your TNAS ID privately? We will verify if the registration was successful?
Roccia7
Italy
Post by Roccia7 »
> [code]cat /var/log/media.log[/code]
> [code]cat /var/log/mediadb/mediadb.log [/code]
Thanks! For the first command here is the log
[2022/06/30 00:44:20] minidlna.c:414: error: check_pg_db:new_db=0
[2022/06/30 00:44:20] minidlna.c:468: warn: New media_dir detected; rebuilding...
[2022/06/30 00:44:20] minidlna.c:481: warn: DROP the tables............
[2022/06/30 00:45:06] scanner.c:881: warn: Unsuccessful getting details for /home/Marco/Android/Tab S2/Backup/Pictures/Telegram/IMG_20190528_225201_877.jpg
[2022/06/30 00:45:49] sql.c:46: error: PGSQL ERROR 7 [ERROR: syntax error at or near "s"
LINE 1: ...', 4277, 'container.storageFolder', 'Valori e Ism's') ON CON...
[2022/06/30 00:45:49] sql.c:47: error: sql=INSERT into OBJECTS (OBJECT_ID, PARENT_ID, REF_ID, DETAIL_ID, CLASS, NAME) VALUES ('3$16$0$10$0$C$6$15', '3$16$0$10$0$C$6', '64$0$10$0$C$6$15', 4277, 'container.storageFolder', 'Valori e Ism's') ON CONFLICT DO NOTHING
[2022/06/30 11:55:28] minidlna.c:414: error: check_pg_db:new_db=0
[2022/06/30 11:55:28] minidlna.c:468: warn: New media_dir detected; rebuilding...
[2022/06/30 11:55:28] minidlna.c:481: warn: DROP the tables............
[2022/06/30 11:56:29] sql.c:141: error: pg_sql_get_int64_field: ERROR 7 [FATAL: terminating connection due to administrator command
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
[2022/06/30 11:56:29] sql.c:142: error: sql=INSERT into DETAILS (NAME, PATH, SIZE, TIMESTAMP, DURATION, DATE, CHANNELS, BITRATE, SAMPLERATE, RESOLUTION, TITLE, CREATOR, ARTIST, GENRE, COMMENT, DLNA_PN, MIME, ALBUM_ART, DISC, TRACK, ALBUM) VALUES ('20210321_120451.mp4', '/Volume1/Foto/Camera/20210321_120451.mp4', 54531191, 1620853537, '0:00:30.206', '2021-05-12T23:05:37', 2, 1805309, 48000, '1920x1080', '20210321_120451.mp4', '(null)', '(null)', '(null)', '(null)', 'AVC_MP4_HP_HD_AAC', 'video/mp4', 0, 0, 0, '-map 0:0 -map 0:1') ON CONFLICT DO NOTHING RETURNING ID;
[2022/06/30 11:56:29] metadata.c:2281: error: Error inserting details for '/Volume1/Foto/Camera/20210321_120451.mp4'!
[2022/06/30 11:56:29] scanner.c:881: warn: Unsuccessful getting details for /Volume1/Foto/Camera/20210321_120451.mp4
[2022/06/30 11:56:35] minidlna.c:414: error: check_pg_db:new_db=0
[2022/06/30 11:56:35] minidlna.c:468: warn: New media_dir detected; rebuilding...
[2022/06/30 11:56:35] minidlna.c:481: warn: DROP the tables............
[2022/06/30 11:56:36] scanner.c:1296: warn: Scanning /Volume1/Multimedia
[2022/06/30 11:56:37] sql.c:46: error: PGSQL ERROR 7 [ERROR: syntax error at or near "Uomo"
LINE 1: ...', 45, 'container.storageFolder', 'Hanno Ucciso L'Uomo Ragno...
[2022/06/30 11:56:37] sql.c:47: error: sql=INSERT into OBJECTS (OBJECT_ID, PARENT_ID, REF_ID, DETAIL_ID, CLASS, NAME) VALUES ('3$16$7$0$3', '3$16$7$0', '64$7$0$3', 45, 'container.storageFolder', 'Hanno Ucciso L'Uomo Ragno') ON CONFLICT DO NOTHING
[2022/06/30 11:57:38] sql.c:104: error: pg_sql_get_int_field: ERROR 7 [ERROR: syntax error at or near "'(select null from DETAILS where MIME like '"
LINE 1: SELECT count(*) from '(select null from DETAILS where MIME l...
[2022/06/30 11:57:38] sql.c:105: error: sql=SELECT count(*) from '(select null from DETAILS where MIME like 'a%' and timestamp > (extract(epoch from now()) - 7776000) limit 50) as audio'
For the second command i receive this
-bash: o@TNAS-220: command not found
OllieHardy
TMSupport wrote:
Am I misunderstanding something, my super user name is OllieHardy, that is what I have been trying to use to log in to TNAS online, across all the servers but it isn't working. Neither is file sharing, I managed to receive a link I sent myself once, but the circular loading symbol displayed for over 12 hours and never loaded
AbandonedTrolley
Post by AbandonedTrolley »
Issue with the install on my T5-221 was previously upto date on the 4.x firmware.
Followed steps on installing new TNAS, installing the package (TOS_X642.0_5.0.125_00162_2206241804) from default factory settings etc.
Now stuck at
http://192.168.0.96:8181/ has the message "Loading pleaes wait" < note the typo
and http://192.168.0.96:8181/tos/#/ has a grey screen with spinning blue wheel, this has been like this for over 30 minutes now.
All lights on the NAS itself are green and fine.
{L_BUTTON_AT}AbandonedTrolley
please refresh the page, or check if your ip address has been changed. search again with the 5.0.27 TNAS PC client.
Bteo
Post by Bteo »
F5-221
I have reinstalled TOS5 2 times. That was the only way to fix the Emby installation.
What I can't seem to make it work is "Terra Photos".
After installation it took for ever to become "Enabled" but even then it does not work.
I can't create Public or Private Spaces. It does not give me any option.
Can't upload any photos.
It's unusable.
Does anyone knows how to fix "Terra Photos"? From a brand new installation and it does not work? Why it's even there?
{L_BUTTON_AT}Bteo
When you click on the settings of Terra Photos, you will see which folder is your private folder, and which folder is your public folder now. you just need to upload your photos to these folders and enable the "media index" on Control panel on your TOS, then you can have your photos show in the app after the media index complete.
