TOS 6.0.530 Official Version Released
dandrewm
Re: TOS 6.0.530 Official Version Released
Post by dandrewm »
I have a F4-424 Pro with TOS 6.0.229 installed. Attempting to manually install this version produced, "Failed to Update". I can't see any other explanations for this and I'd rather not have to flash using USB Initboot. Does anyone have any insights on what the issue might be?
ckellawan
Post by ckellawan »
dandrewm wrote: 25 Dec 2024, 16:50 I have a F4-424 Pro with TOS 6.0.229 installed. Attempting to manually install this version produced, "Failed to Update". I can't see any other explanations for this and I'd rather not have to flash using USB Initboot. Does anyone have any insights on what the issue might be?
I was faced with the same results, attempting to upgrade my F4-223, from 6.0.229. It kept failing at 40%. I tried uploading from my PC, from a USB attached to the NAS, and from a local folder on the NAS. Didn't make a difference. So, I thought, let's back up your profile, reset it, then restore it. Well, upon restoring the original profile, the NAS was in a strange state. I couldn't log in via TOS desktop or https, but I could connect via SMB, using the restored credentials.
One more point to note, I have an 512GB M.2 drive installed, originally for Hyper Cache. However, before attempting to upgrade, I deleted the Hyper Cache and virtually removed the drive. Then I manually shut down the NAS.
Removing all the drives, except the M.2, I powered it backed on. I was then prompted to install TOS via the internal USB or download, I chose download. Reinstalled my drives. When asked to select which drives to install TOS to, I unselected all drives, except the M.2. I then had a clean install of TOS 5.1.145. Powered down. Powered back up, verified volume intact, upgraded to 6.053.
After that, I once again wasn't able to login via TOS desktop or browser, but I new it was functioning to some extent because my winNUT client was connected. Manual reboot, came back up, took an automatic update to 6.0.55, has been purring like a kitten ever since. YMMV
TMbuddy
Post by TMbuddy »
The current online TOS version is 6.0.577. Did you update to 6.0.530 or 6.0.577 ?
ckellawan
Post by ckellawan »
TMbuddy wrote: 26 Dec 2024, 18:45
I did this two days ago, at that time the online version that installed for me was 5.1.145.
sae24
Post by sae24 »
Я тоже не понимаю почему забили на модель F4-422, но говорят надо ждать.
wefixsarzana
Italy
Post by wefixsarzana »
after update i lost all the data the traid is there but says it's damage how i can retrive the data ?
waymda
Australia
Post by waymda »
Am I right in thinking this update drops ALL configuration info?
Will data be lost?
Is it safe to do on a T9-423 with 5.1.67 TOS and 5.19 boot?
How can I produce a print out of current system settings to re-apply?
thanks
wefixsarzana
Italy
waymda wrote: 30 Dec 2024, 14:24 Am I right in thinking this update drops ALL configuration info?
Will data be lost?
thanks
i tried and now don't have my data and to do all setting , but waiting for someone to help me becouse i think the data is still there
Please update to the latest TOS5 first to meet the upgrade requirements on the first page of this topic. This upgrade will clear the configuration without affecting the data, provided the conditions are met.
Hexmit
Spain
Post by Hexmit »
Hi there!
Nice to see that the TOS 6 is here :)
Got some doubts (maybe already solved somewhere)
- What kind of configs are wiped? Only system ones?
- Will the volumes and data be safe ? Asking because this Update seems to be quite big and there is a lot of data.
- If I'm running services through Docker, will this update break the Docker config too ? Maybe only need to update but want to ask.
