I simply posted info in an attempt to get better ideas of the issue and from what I see in several years there has been little posted in this thread so maybe this example right here is part of what I am pointing out that not only is there limited info, one other person that chimes in that isn't the dev is less than helpful, just condescending.
[ qBittorrent + CLI ] An open-source software alternative to µTorrent
- jestermgee
Re: [ qBittorrent + CLI ] An open-source software alternative to µTorrent
Before it was still the app made by you - qBittorrent TOS6 5.1.2.0 x86_64 downloaded via https://tmnascommunity.eu/download/qbittorrent/
This app on Tos7 is using a slightly different path to store the config files comparing with TOS6. I will provide an update version that will reatore the old config and data if the TOS system is upgraded.
Try version 5.2.2.2m4niekk90 wrote: ↑28 Jun 2026, 15:27Before it was still the app made by you - qBittorrent TOS6 5.1.2.0 x86_64 downloaded via https://tmnascommunity.eu/download/qbittorrent/
@outkastm This is perfect ! All my previous torrents are back altoghether with most recent ones. Thank you so much for your help !
Hi! Please send the application version for f2-212 (arm) with tos 5.1 ? If I am right, it is 5.0.130
question - I have t4-220 TOS 5.1.67 and downloaded qBittorrent from https://tmnascommunity.eu/download/qbit ... Bittorrent TOS7_TOS6 5.2.2.2 x86_64.tpk and that is not working - The fille is incorrect and stops
Can't find in in the app centre on the NAS . Can't find any apps in the app centre - to begin with.
Where I can find right download file .tpk ?
You are running Tos5. That download appears to be for Tos6 and/or Tos7. You would need to find a Tos5 compatible version.
F2-221 TOS7.0.1422 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1341 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
Ciao avrei bisogno della versione qBittorrent v4.4.3.1 Web UI (64-bit) qualcuno può darmi un link ? grazie
