How to manually install 3rd Party Apps and the list with available apps
JamesD
Ukraine
Re: How to manually install 3rd Party Apps and the list with available apps
Post by JamesD »
Hello, I am quite new to Terramaster. I am trying to install Tailscale on my F6424Max. It gives me an error "file is incorrect and cannot be installed"
My intention is to connect my TM here to a synology in another locat (LAN) so I can use RSYNC securely.
I have downloaded Tailscale TOS6 194 .2.0 aarch64.tpk for the TM and have installed Tailscale on the Win11 pc in the same LAN as the TM.
I was wondering if I should another linux tailscalle installation package, or any recommendations would be greatly appreciated.
Your NAS is based on x86 architecture, download the correct file with x86_64 in the filename
crisisacting
Post by crisisacting »
JamesD wrote: ↑14 Apr 2026, 00:16 … have downloaded Tailscale TOS6 194 .2.0 aarch64.tpk for the TM …
That's the build meant for TOS 6 ARM builds, not for your ×86/×64 TNAS model.
Follow what @outkastm posted to get the correct one.
carltorn60
Sweden
Post by carltorn60 »
I just installed Roonserver and now I'm stuck. My shared folder is not showing up so that I can add it In Roon. And I can't find away to add on TNAS either (getting a 404 not found error). Like where Roon should look for music. Adding some screenshots from my NAS/PC.
Any help is appriciated.
Regards/Carl
