ive just created a new one from mine, and found that path names are case sensitive otherwise i get an error message
i.e i had shared it on my F2-210 as Music and i tried typing in music and it wouldn't allow it
[Help] TOS7 cannot mount remote SMB folders.
- sianderson
- Silver Member
Re: [Help] TOS7 cannot mount remote SMB folders.
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
- FredMutter
as you can see on my previous post and this screenshot: paths in the unix terminal or in the dialog are the same => Photossianderson wrote: ↑18 Apr 2026, 19:53 ive just created a new one from mine, and found that path names are case sensitive otherwise i get an error message
https://postimg.cc/NyY0c6yp
Model: F2-424 with TOS 7.0.1105 - currently changing every month
- Bios V08
In TOS7 the interface is modified so that only the 'server' IP is entered initially with credentials and then, in a subsequent dialogue the user can select the appropriate path(s) via a browse style selection (if needed).FredMutter wrote: ↑18 Apr 2026, 16:52 And I do have TOS 6 indeed.
But I suppose the problem remains with TOS 7. This is why I want to contact the hotline
Frustrated Beta Tester!!!
- FredMutter
That’s great to hear!Gremlin wrote: ↑18 Apr 2026, 21:28In TOS7 the interface is modified so that only the 'server' IP is entered initially with credentials and then, in a subsequent dialogue the user can select the appropriate path(s) via a browse style selection (if needed).FredMutter wrote: ↑18 Apr 2026, 16:52 And I do have TOS 6 indeed.
I’ll share the solution on Monday.
Here’s the thing: I can mount my remove directory on many Macs.
However, with TOS 6, it only works with the Unix shell and not the user interface.
In SMB Advanced dialog, I enabled the journal/log, but the SMB log stays empty (to be seen in the Journal dialog) . (Maybe it only works when TOS is the SMB server and not the SMB client.)
- Bios V08
- FredMutter
So the engineers tried to find the error.Gremlin wrote: ↑18 Apr 2026, 21:28In TOS7 the interface is modified so that only the 'server' IP is entered initially with credentials and then, in a subsequent dialogue the user can select the appropriate path(s) via a browse style selection (if needed).FredMutter wrote: ↑18 Apr 2026, 16:52 And I do have TOS 6 indeed.
After 2 hours of research they may have something: it is definitely a bug.
They will internally try to reproduce the problem then update some executables (ie. smbclient) .
They will contact me again and we will try a patch together
- Bios V08
I am having the same problem. When I mount a remote folder from my Netgear ReadyNAS, nothing appears. I found I have to mount the root folder and then modify it to a subfolder manually to get it to work. The problem with that workaround is the root folder remains connected until the NAS (F2-425) is rebooted, but doesn't show up in remote folders.
- FredMutter
I haven’t heard back from the engineers, so I assume they’ve stopped the investigation.
- Bios V08
We sincerely apologize for the lack of communication. Please rest assured that our team is still actively working on this issue.
Following the remote diagnostic session, our engineers have confirmed a compatibility issue between TOS 6 and macOS SMB services. We are currently in the "internal testing and fixing" phase. The fix is being developed and will be included in an upcoming software update.
Thank you for your valuable feedback, and we truly appreciate your continued patience and support while we resolve this technical challenge.
- FredMutter
That’s good to hear.EriChan wrote: ↑25 Apr 2026, 15:32We sincerely apologize for the lack of communication. Please rest assured that our team is still actively working on this issue.
If your teams confirms that this issue only affects TOS 6, then a fix or patch isn’t necessary for me.
I’ll wait for TOS 7.
(If you need someone to test it, I’d be happy to help.)
- Bios V08
Thank you for your understanding and support. We will verify the results as soon as possible and inform you. We will contact you if needed further. Thank you again for your support and assistance in optimizing the TOS system.
