[Help] Disable/mute boot buzzer  [SOLVED]
Felix
Re: [Help] Disable/mute boot buzzer
Post by Felix »
nenominal wrote: ↑03 Apr 2026, 03:20 Hi,
Thanks for the answer.
I don't have mechanical disks, only SSD and nvme.
It's possible to be the PSU or a mechanical relay switch, I don't know.
If your device does not have a mechanical hard drive, then the most likely source of the slight mechanical start-up sound is the cooling fan.
