TOS 7.0.0408 Beta (X86) is Released for Update
Joesh
Indonesia
Re: TOS 7.0.0408 Beta (X86) is Released for Update
Post by Joesh »
Updated successfully
rfbjr wrote: 03 Mar 2026, 23:39
We have identified a known issue where clicking to open an application may occasionally have no effect. This has been addressed in the new version, so please wait for the upcoming release.
star
Sweden
Post by star »
Smb fails to give permissions to user. shared folders fails to give permission to folders.
star wrote: 04 Mar 2026, 12:28
Not quite sure what you mean.
Updated to .408 this morning and have no issue with access via SMB (even remote mounted folders). Permissions appear to be as per previous version.
star
Sweden
Post by star »
Gremlin wrote: 04 Mar 2026, 20:01
when i assign a folder to a user in the share folder permission section and save, he gets no permissions.
However if i assign it in terminal with commands it works.
Not sure why it does not save permissions selected in web gui.
rfbjr
Post by rfbjr »
rfbjr wrote: 03 Mar 2026, 20:11 That was a bit scary. F6-424 updated fine, yes, the hibernation settings were not on, if off prior to upgrade.
The F4-425 Plus looked fine, but when I logged on, it said no volume/storage pool. Status showed corrupt.
Manually rebooted it again, everything back up normal. Generating a system report, I'll upload it later.
Ok let's just say (on my F4-425 Plus)t that the Volume/Storage pool was corrupt, what would be the steps to repair it?
I have filesystem snapshots turned on, would I just go and do a restore? My guess is that won't stop the RAID from needing a re-sync?
I rather know my options now rather than in a panic mode.
F6-424 & F4-425 Plus at 7.0.1163
F4-424 Pro (x2) also at 7.0.1163
D4-320
Joesh
Indonesia
Post by Joesh »
Same with you, found no issue with access via SMB after updated
MikeZhang
Post by MikeZhang »
rfbjr wrote: 05 Mar 2026, 02:21
It's recommended to book remote support from official site online chat, we will help fix for you remotely.
rfbjr
Post by rfbjr »
MikeZhang wrote: 05 Mar 2026, 19:03
Ok
D4-320
joka388
Austria
Post by joka388 »
Sleep Mode for HDD will not work on F2-221
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
