[Help] F5-221 is doing sporadic reloads
- AlAleksiev
Re: [Help] F5-221 is doing sporadic reloads
You have the debug data collected now - I hope it will help you to figure out what's going on with the TOS.
I send it to [email protected]
Please, let me know if you need something else!
______________________
F5-221; 10G RAM; 5 x 4TB TRAID; Riser, Power and/or ASMedia HW failure undetected by TM Support
F6-424; 32G RAM; 2 x 512GB 8Gb/s M.2; 6 x 4TB raidz2; TrueNAS 25.10.1
¯¯¯¯¯¯ Jellyfin, Pi-Hole, Unifi Controller, Zabbix
When the Debug mode is started, exceptions are not recorded. Please let it encounter an exception when running in Debug mode so that relevant information can be collected.
- AlAleksiev
Debug is enabled and I started all the containers (Jellyfin, Proxy.py and Pi-Hole) to have a realistic minimal load.
What is weird though is that the files in the debug folder are not growing:
I'll record the moment of the crash to faciliate your searching, but the above files are kind of concerning...
Cheers
Cheers
- AlAleksiev
The new debug data is sent to [email protected] - for the crash at 2025/12/16 in 22:56:55 EST
- AlAleksiev
This is what I found interesting in the debug information:
From the kernel log - nothing abnormal
The ATOP log is giving a good information.
The first conclusion seems to be related to the RAM. TOS v6 is consuming it pretty well and for the F5-211 platform default 2GiB is reaching the limit.
The updated containers are using more RAM than their old versions and that's pushing the limits as well.
I alreay ordered one SODIMM
I'll add it tomorrow and we'll see if that's going to fix the issue ...
- IPv6 is diabled, but TOSDaemon is still trying to use it
- msgcenter is fooled by the docker host container for a duplicated IP
- containers' healthcheck interval is too small
--------------------------- syslog ---------------------------
Dec 16 22:52:27 TNAS-ALEX TOSDaemon[4907]: getIP http get failed url=https://ipv6.seeip.org error=Get "https://ipv6.seeip.org": dial tcp [2602:fed3:2:b75e:ecd:7ec4:6bcb:c6d3]:443: connect: cannot assign requested address
Dec 16 22:52:39 TNAS-ALEX systemd[1]: run-docker-runtime\x2drunc-moby-4aec740d5ce4618ce2423b8f32ecd51ed1b4a456e914ea4428e6bdb2bda1b56e-runc.jothka.mount: Deactivated successfully.
Dec 16 22:56:04 TNAS-ALEX systemd[1]: run-docker-runtime\x2drunc-moby-0fe8960743a0fe860b456aa548923d052b919d78989920041e205abfeccd4f0f-runc.gqd4il.mount: Deactivated successfully.
<<<<<<<<<< CRASH >>>>>>>>>>>
Dec 16 22:59:15 TNAS-ALEX systemd-modules-load[318]: Module 'ecryptfs' is built in
Dec 16 22:59:15 TNAS-ALEX mdadm[320]: DeviceDisappeared event detected on md device /dev/md0
Dec 16 22:59:15 TNAS-ALEX systemd-modules-load[318]: Inserted module '8812au'
Dec 16 22:59:15 TNAS-ALEX mdadm[320]: DeviceDisappeared event detected on md device /dev/md8
-------------------------- kern.log --------------------------
Dec 16 22:38:35 TNAS-ALEX 1 2025-12-16T22:38:35-05:00 - - TOSDaemon(4907) - [attrs ws="rpc"] normal closed connection
Dec 16 22:59:15 TNAS-ALEX kernel: [ 0.000000] Linux version 6.1.120+ (root@51f02058744a) (x86_64-tnas-linux-gnu-gcc.br_real (Buildroot 2023.08.1) 13.2.0, GNU ld (GNU Binutils) 2.40) #52 SMP PREEMPT_DYNAMIC Thu Nov 27 09:25:39 CST 2025
Dec 16 22:59:15 TNAS-ALEX kernel: [ 0.000000] Command line: BOOT_IMAGE=/boot/bzImage type=raid hpet=disable security=
- RAM is exhausted
- TOSDaemon is consuming a lot of memory from the beginning
- No available memory for processes like Jellyfin
----------------- LAST ATOP BEFORE THE CRASH -----------------
ATOP - TNAS-ALEX 2025/12/16 22:56:15 ----------------- 30s elapsed
PRC | sys 1.21s | user 1.93s | #proc 269 | #trun 3 | #tslpi 324 | #tslpu 131 | #zombie 0 | clones 100 | #exit 72 |
CPU | sys 4% | user 7% | irq 1% | idle 186% | wait 3% | ipc 0.47 | cycl 188MHz | curf 2.00GHz | curscal 79% |
cpu | sys 2% | user 3% | irq 0% | idle 93% | cpu001 w 1% | ipc 0.45 | cycl 188MHz | curf 2.50GHz | curscal 100% |
cpu | sys 2% | user 3% | irq 0% | idle 93% | cpu000 w 2% | ipc 0.49 | cycl 188MHz | curf 1.50GHz | curscal 59% |
CPL | avg1 0.32 | avg5 0.24 | avg15 0.38 | | csw 56926 | | intr 56871 | | numcpu 2 |
MEM | tot 1.8G | free 75.5M | cache 749.9M | dirty 0.6M | buff 2.7M | slab 108.0M | shmem 109.0M | shrss 0.0M | numnode 1 |
SWP | tot 1.9G | free 1.7G | swcac 36.8M | | | | | vmcom 3.0G | vmlim 2.8G |
PAG | scan 34 | steal 34 | stall 1 | compact 1 | numamig 0 | migrate 2922 | swin 2 | swout 0 | oomkill 0 |
LVM | vg0-lv0 | busy 1% | read 12 | write 70 | discrd 0 | KiB/w 64 | MBr/s 0.0 | MBw/s 0.1 | avio 4.27 ms |
MDD | md0 | busy 0% | read 12 | write 68 | discrd 0 | KiB/w 65 | MBr/s 0.0 | MBw/s 0.1 | avio 1.41 ms |
MDD | md8 | busy 0% | read 2 | write 0 | discrd 0 | KiB/w 0 | MBr/s 0.0 | MBw/s 0.0 | avio 9.00 ms |
PID TID MINFLT MAJFLT VSTEXT VSLIBS VDATA VSTACK LOCKSZ VSIZE RSIZE PSIZE VGROW RGROW SWAPSZ RUID EUID MEM CMD 1/15
29365 - 69 0 44.0K 99.3M 422.8M 132.0K 0.0K 260.8G 335.0M 324.0M -48.0K -1.1M 500.0K ****** ****** 18% jellyfin
4907 - 0 1 35.9M 47.3M 216.2M 132.0K 0.0K 2.3G 168.8M 165.4M 0B -8.0K 90.9M ****** ****** 9% TOSDaemon
5541 - 0 0 31.2M 4.0K 61.7M 132.0K 0.0K 1.2G 34.3M 35.7M 0B 0B 2.2M ****** ****** 2% portainer
----------------- FIRST ATOP AFTER THE CRASH -----------------
ATOP - TNAS-ALEX 2025/12/16 22:59:38 ----------------- 1m31s elapsed
PRC | sys 10.04s | user 29.53s | #proc 274 | #trun 6 | #tslpi 219 | #tslpu 140 | #zombie 0 | clones 5038 | #exit 11 |
CPU | sys 44% | user 101% | irq 1% | idle 46% | wait 8% | ipc initial | cycl initial | curf 2.40GHz | curscal 95% |
cpu | sys 22% | user 50% | irq 0% | idle 23% | cpu000 w 4% | ipc initial | cycl initial | curf 2.40GHz | curscal 95% |
cpu | sys 22% | user 50% | irq 0% | idle 23% | cpu001 w 4% | ipc initial | cycl initial | curf 2.40GHz | curscal 95% |
CPL | avg1 6.10 | avg5 2.30 | avg15 0.83 | | csw 363204 | | intr 308563 | | numcpu 2 |
MEM | tot 1.8G | free 372.4M | cache 574.9M | dirty 1.4M | buff 17.3M | slab 85.6M | shmem 31.4M | shrss 0.0M | numnode 1 |
SWP | tot 1.9G | free 1.9G | swcac 0.0M | | | | | vmcom 2.3G | vmlim 2.8G |
LVM | vg0-lv0 | busy 4% | read 533 | write 95 | discrd 0 | KiB/w 69 | MBr/s 0.3 | MBw/s 0.1 | avio 5.62 ms |
LVM | vg0-lv1 | busy 1% | read 242 | write 0 | discrd 0 | KiB/w 0 | MBr/s 0.1 | MBw/s 0.0 | avio 4.77 ms |
MDD | md9 | busy 11% | read 7321 | write 1205 | discrd 0 | KiB/w 4 | MBr/s 5.8 | MBw/s 0.1 | avio 1.20 ms |
MDD | md0 | busy 5% | read 896 | write 93 | discrd 0 | KiB/w 70 | MBr/s 0.5 | MBw/s 0.1 | avio 4.65 ms |
MDD | md8 | busy 0% | read 102 | write 2 | discrd 0 | KiB/w 4 | MBr/s 0.0 | MBw/s 0.0 | avio 2.42 ms |
DSK | sdb | busy 15% | read 4568 | write 2895 | discrd 0 | KiB/w 116 | MBr/s 4.0 | MBw/s 3.6 | avio 1.76 ms |
DSK | sda | busy 11% | read 2803 | write 2653 | discrd 0 | KiB/w 3 | MBr/s 5.7 | MBw/s 0.1 | avio 1.89 ms |
DSK | sdd | busy 2% | read 468 | write 75 | discrd 0 | KiB/w 54 | MBr/s 0.2 | MBw/s 0.0 | avio 3.03 ms |
DSK | sde | busy 2% | read 547 | write 71 | discrd 0 | KiB/w 54 | MBr/s 0.2 | MBw/s 0.0 | avio 2.61 ms |
DSK | sdc | busy 2% | read 471 | write 66 | discrd 0 | KiB/w 53 | MBr/s 0.2 | MBw/s 0.0 | avio 2.96 ms |
NET | transport | tcpi 5945 | tcpo 5899 | udpi 170 | udpo 383 | tcpao 39 | tcppo 33 | tcprs 5 | udpie 0 |
NET | network | ipi 6599 | ipo 6517 | ipfrw 0 | deliv 6577 | | | icmpi 212 | icmpo 0 |
NET | eth1 0% | pcki 483 | pcko 283 | sp 1000 Mbps | si 5 Kbps | so 3 Kbps | erri 0 | erro 0 | drpo 0 |
NET | eth0 0% | pcki 278 | pcko 341 | sp 1000 Mbps | si 2 Kbps | so 2 Kbps | erri 0 | erro 0 | drpo 0 |
NET | lo ---- | pcki 6031 | pcko 6031 | sp 0 Mbps | si 112 Kbps | so 112 Kbps | erri 0 | erro 0 | drpo 0 |
NET | bond0 ---- | pcki 685 | pcko 624 | sp 0 Mbps | si 6 Kbps | so 6 Kbps | erri 0 | erro 0 | drpo 0 |
*** System and Process Activity since Boot *** Rawfile view
PID TID MINFLT MAJFLT VSTEXT VSLIBS VDATA VSTACK LOCKSZ VSIZE RSIZE PSIZE VGROW RGROW SWAPSZ RUID EUID MEM CMD 1/13
4566 - 8708 35 35.9M 46.7M 168.5M 132.0K 0.0K 2.0G 257.0M 253.5M 2.0G 257.0M 0B ****** ****** 14% TOSDaemon
432 - 3686 0 7.3M 7.5M 133.1M 132.0K 0.0K 1.9G 43.4M 42.3M 1.9G 43.4M 0B ****** ****** 2% ter_storage_de
4568 - 2667 9 16.3M 1.9M 122.4M 132.0K 0.0K 1.8G 35.4M 35.2M 1.8G 35.4M 0B ****** ****** 2% nasips
425 - 5120 48 5.6M 16.4M 1.8M 132.0K 0.0K 214.6M 31.0M 10.3M 214.6M 31.0M 0B postgres postgres 2% postgres
4578 - 3949 4 5.0M 5.6M 96.5M 132.0K 0.0K 1.6G 30.8M 29.4M 1.6G 30.8M 0B ****** ****** 2% twm_authentica
- AlAleksiev
The additinal memory is added and that's the result from two long-time stress tests
After more than 9 hours (overnight) running on-line SilverBench stress test from SystemRescue live Arch linux:
More than 4 hours running on-line CPU Expert stress test from Mint live installation (Debian based like TOS):
In both cases the hardware is stable and responsive.
Now starting TOS in 14:54:28 EST - debug enabled.
It survived only 15 minutes - the crash came in 15:09:48 EST.
This is in the moment of the crash - all parameters looks good: CPU, RAM, Network, Disks activity, Docker containers
It should be something with the TOS itself, right?
- AlAleksiev
New Install - after Factory Default (and configuration backup)
eth0 mac: 6cbf.b501.5f4c assigned initial ip 192.168.0.163 (dhcp 016c.bfb5.015f.4c)
eth1 - disconnected
Note: No one of the specified in the post (viewtopic.php?t=6433) initboot images is accepted!
The recommended "Online download" way used - the console log shows: initBoot (567)
Same method was used for the Bootloader. That one was staying on 99% ready for more than 10 minutes. On the console we have that
Specified local (md5 verified) TOS image:
The TOS installation was waiting longer on 60% (maybe the existing arrays were resyncing) then jumped on 92%, 100%
finally reload...
EULA confirmed, user created, security email - code passed
Security Advisor initiated: HTTP(S) ports, SPC, Isolation and Snapshot at risk
- for HTTP(S) ports changed to 7171 / 7443
Waiting to validate stability
5 minutes later - it shutdown himself with no reload this time.
Any suggestions for next step?
eth1 - disconnected
finally reload...
- AlAleksiev
As suggested on a chat session, enabled the debug and sent the log to [email protected]
... waiting for technical opinion ...
Hi.
Many users who use this NAS model and system, like you, have not encountered similar issues. The available information does not clearly indicate the source of the problem.
Next, it may be necessary to consider checking power supply-related issues. Are you currently connected to a battery/UPS instead of mains power?
Is the power adapter original? Is its LED light bright? What is its output voltage (V)?
If you have an adapter with 1.5 times or even higher output power than the original one for the 12V 5.5*2.5 interface, you can try replacing it for testing.
- AlAleksiev
Already verified that in a simple way - System Rescue live USB running more that 24 hours and the NAS is in the same conditions:
- same UPS (for any power variations ^ outlet problems)
- same ethernet bond (for any load-balancing related problems)
- same switch on the same ports (for any static electricity problems)
- same KVM
I enabled samba on the System Rescue (Arch linux actually), mounted the existing LVs and shared them on the local network.
Everything is working stable and fast.
Few photos to give you more details:
Any other suggestions?
- same KVM
