[Help] F4-425 Plus Intel N150 low performance  [SOLVED]
shou
Singapore
Re: [Help] F4-425 Plus Intel N150 low performance  [SOLVED]
Post by shou »
baf28 wrote: 25 Nov 2025, 18:55
Sorry, the previous instructions were incorrect. The path has been corrected: after pressing F3 in the BIOS to load the default settings, please reconfigure the PL1 parameter according to the revised steps.
1,Press Del to enter BIOS during startup.
2,Navigate to the following path:Advanced → Power & Performance → CPU-Power Management Control → View/Configure Turbo Options.
3,Set Power Limit 1 Override Enabled.
4,set the item "Power Limit 1" to 15000.
baf28
Post by baf28 »
shou wrote: 25 Nov 2025, 19:24
Thank you so much!!! This completely solved the problem with productivity. I'll be watching the temperatures, but I don't think it will be a problem, because In fact, N95 cools down in the same way as here.
https://browser.geekbench.com/v6/cpu/15224501
Din0
Czech Republic
Post by Din0 »
I set PL1=18000 and PL2=25000 in BIOS but no performance improvement.
What do I need to enable for it to work?
Platform PL1 Enable = Enabled?
Platform PL2 Enable = Enabled?
Power Limit 1/2 Override?
Any other settings?
Also:
Should I reset BIOS (F3) first?
Is 18000 for PL1 too high? What's optimal?
Please share complete settings needed.
Thanks!
baf28
Post by baf28 »
Din0 wrote: 18 Jan 2026, 15:41 Please share complete settings needed.
Here https://bafista.ru/obzor-terramaster-f4 ... m-dizajne/ I painted all the necessary settings in the pictures
Din0
Czech Republic
Post by Din0 »
Update – issue resolved.
Final working configuration:
- Power Limit 1 Override: Enabled
- PL1 Power: 15000
With this setup, Geekbench 6 now reports:
Single‑Core: 1299
Multi‑Core: 3178
https://browser.geekbench.com/v6/cpu/16142862
During the test, CPU temperature did not exceed 85°C.
Thanks for the help!
Return to “System Resources”
