[Help] TNAS Mobile App on Iphone failing uploading photos
MikeZhang
Re: [Help] TNAS Mobile App on Iphone failing uploading photos
Post by MikeZhang »
ubdai66 wrote: ↑04 Jun 2026, 21:18
Please uninstall mobile app and install again via the link https://testflight.apple.com/join/wFWYABJS
Update to latest TOS version then test again viewtopic.php?t=10135
rfbjr
Post by rfbjr »
Ipad 11th gen (IOS 26.6 Beta)
current mobile version of tnas app (3.5.068)
TOS 7 v616
First showing preping 14, just stays there for hours
Stop the sync, start again, it will instantly upload a few pictures, then stalls.
Stop the sync, start it again, same thing it will process a few then stall
3rd time, same then all are uploaded
F4-424 Pro (x2) at 7.0.1298
ubdai66
Post by ubdai66 »
Please uninstall mobile app and install again via the link https://testflight.apple.com/join/wFWYABJS -
This has been done
Difficulty in upgrading TOS as system says a .bz2 file is needed for manual update from 7.0.0500. it states
Update check failed. Please check your network connection and try again.
At a loss now. :|
MikeZhang
Post by MikeZhang »
rfbjr wrote: ↑05 Jun 2026, 09:24
You may export log for iOS: My iPhone/TNAS mobile/Log and send to support email for analysis
MikeZhang
Post by MikeZhang »
ubdai66 wrote: ↑05 Jun 2026, 19:27
Please try again with update package--https://download3.terra-master.com/TOS% ... 261432.bz2
rfbjr
Post by rfbjr »
MikeZhang wrote: ↑06 Jun 2026, 07:19
Will do. Thank you
ubdai66
Post by ubdai66 »
MikeZhang wrote: ↑06 Jun 2026, 07:21
Ok. So ive download the file and now updating with a bz2 file
Only issue is update seems to now be stuck at 70%
Why does everything seem to be so difficult for a somewhat simpler operation?
Phil
Post by Phil »
ubdai66 wrote: ↑07 Jun 2026, 20:39
Thank you for your feedback. I apologize for the previous errors. I checked your previous posting history and found that your machine is based on the ARM architecture. Your current version 7.0.0500 is already the latest version and does not support the 7.0.616 update.
ubdai66
Post by ubdai66 »
Phil wrote: ↑07 Jun 2026, 21:41
Ok then. But the upload issue from iPhone to NAS using the Apple Testflight TNAS lastest Beta still exists. How do we resolve this issue?
ubdai66 wrote: ↑07 Jun 2026, 21:59
Are your backed-up photos stored locally on your iPhone or in iCloud? Currently, it's not possible to directly back up photos stored in iCloud.
If they are stored on your iPhone, you can export the iOS log: My iPhone/TNAS mobile/Log, and send it to the support email address for analysis.
To quickly locate your issue, please include a link to this post in the body of your email.
