[Help] F4-210 wifi connectivity issue
EnchanterTheTim
Re: [Help] F4-210 wifi connectivity issue
Post by EnchanterTheTim »
OrionXie wrote: ↑30 Apr 2025, 15:40
EnchanterTheTim wrote: ↑30 Apr 2025, 00:13
We are very sorry for causing you a bad experience. Please provide us with the specific version of the NAS TOS system, and we will provide it to the laboratory for reconfirmation.
It's F4-210.
The current TOS version is: 4.2.41-
And software update is set to online
crisisacting
Post by crisisacting »
EnchanterTheTim wrote: ↑30 Apr 2025, 23:31It's F4-210.
There's a point release to 4.2.44 available @ https://download3.terra-master.com/TOS% ... 260950.bz2 (it's the latest publicly available build for the 210 series devices).
EnchanterTheTim
crisisacting wrote: ↑01 May 2025, 00:24
Thanks, I updated. Still get the error.
EnchanterTheTim
OrionXie wrote: ↑30 Apr 2025, 15:34
If the encryption type cannot select anything other than WPA, you can set the encryption type of WiFi to WPA in the Nokia Beacon 2 router. After making it consistent with the supported encryption type of WiFi, try to connect. If it still doesn't work, you can try your ASUS router. Of course, the encryption type of wifi is still set to WPA. It is best to migrate to the final place you need to put it after the nas and the router are connected at a short distance. I hope this is helpful to you.
I'm unable to even connect it via Ethernet to the Asus router. It doesn't even see the NAS. I've literally spent hours on this since the last time we talked. Can you provide a link to a USB wireless card that is certified compatible with my NAS?
The forum cannot provide product links. You can contact us through the official website's Live Chat.
Return to “Network”
