Re-enabling volume encryption in TOS6
Re: Re-enabling volume encryption in TOS6
:idea: It could be
Terra-master
Operating
System
Secure
Enterprise
Release
:o :lol:
Frustrated Beta Tester!!!
athurdent
Germany
Post by athurdent »
Gremlin wrote: ↑17 Aug 2025, 19:54
storageninja wrote: ↑17 Aug 2025, 17:27 Adding this feature would significantly increase trust and adoption among security-conscious customers.
and, no doubt, make it more expensive for the budget minded users in the long run. In which case I would suggest an "Enterprise TOS" which could have all the bells and whistles AT A PRICE!
No need to yell, I for one would not mind paying for that security feature. Although it seems the backend already has (some) LUKS support, if you skim through the script I listed above.
Plus, LUKS and TCG/Opal are pretty well documented and would not require TerraMaster to reinvent the wheel. Surely extra caution/testing has to be applied so users don’t loose their data.
IIRC, the build in folder encryption that is based on eCryptfs is no longer actively maintained, so unless TerraMaster want to start fixing issues there in future releases, best to go for supported software anyways. TCG Opal, low hanging fruit: the drives already encrypt in hardware, the only thing that has to be done is change that encryption key to a password only known to you. Limit this kind of encryption to non-system drives, and there’s most likely no major change required. Easy to set a new password: https://wiki.archlinux.org/title/Self-e ... your_drive
jay616
Post by jay616 »
TMzethar wrote: ↑05 Aug 2025, 17:10 Regarding AES 256-bit Disk Array Encryption Protection, it has never been implemented. This was an oversight, and I have informed the team to either modify the description or remove it.
This is terrible. I bought the F4-F25 Plus to replace my old NAS as I required disk encryption and the Synology I had didn't support it. Based on the press release, i assumed it would be supported.
This feature needs to be added for TOS to be an option for a lot of users.
athurdent
Germany
Post by athurdent »
jay616 wrote: ↑24 Oct 2025, 21:15
That, 100%.
Especially because the base OS already has support, there were even scripts for LUKS last time I checked.
ATOMFIX
Post by ATOMFIX »
Making my comment here in the hope it makes a difference.
Yes to encryption! Please add this feature.
Plex F6-424 - 3x 12TB - 1x 4TB - 500GB SSD - 1TB NVME
Kristy21
Post by Kristy21 »
TMnick wrote: ↑26 Apr 2025, 18:34null's brawlHello, could you please share a screenshot of this feature in TOS 5? We don’t have this functionality implemented in the UI for TOS 5 or 6—it can only be executed via command line.
Is the development team aware that encrypted LUKS volumes become invisible and unmanageable in the TOS WebUI? Are there any plans to add basic WebUI visibility or a simple unlock/mount dialogue for LUKS volumes to support advanced users?
Currently, only folder-level encryption is supported. We will feedback the request for encrypted volumes to the product team for evaluation.
Nollsbrool
Post by Nollsbrool »
Kristy21 wrote: ↑18 Nov 2025, 17:22
TMnick wrote: ↑26 Apr 2025, 18:34Null’s Brawl ModsHello, could you please share a screenshot of this feature in TOS 5? We don’t have this functionality implemented in the UI for TOS 5 or 6—it can only be executed via command line.
No, as I do know the TerraMaster development team does not officially support or track custom LUKS layers, meaning encrypted LUKS volumes remain completely invisible and unmanageable in the TOS WebUI by design.
Tommyviech
Germany
Post by Tommyviech »
Hello there,
new here so as i see it actually, there is no volume encryption with password supported, only the folder based encryption in TOS 7?
The main problem with the folder encryption is its limitation to 143 characters for filename and path!!!
With this i will not have a chance at all to encrypt my complex directory trees with long filenames etc.!
As i am not yet a TerraMaster owner (this encryption issue is my MAIN factor for the choice) i couldn't find information on how the folder based encryption is done. Are the file and directory NAMES also encrypted or just the file content and will someone who gets access to the NAS or steales it and reads the disc drives themselves be able to SEE the directory tree and file names in plain text?
A volume based encryption with a user defined password (like TrueNAS offers) would HEAVILY improve usability and security!
PS:
I was ever wondering why noone ever implemented somewhat like 'mounting a veracrypt container as a shared folder' (with manual mounting the container with password after NAS reboot). That would be at least a workaround. (I know, the VC-container size would be fix)
EriChan
Post by EriChan »
Tommyviech wrote: ↑13 Aug 2026, 15:52
Thank you for your feedback!
We fully understand your concern regarding volume-based encryption. This feature is already in our product roadmap, so please stay tuned for future updates!
