TNAS mobile does not see NAS
TMtina
Re: TNAS mobile does not see NAS
Post by TMtina »
Noah wrote: ↑13 Mar 2025, 14:32 I'm trying to use the TNAS Mobile 3 app on my Android 9 phone, but it doesn't seem to work. The app either crashes or fails to connect to my TNAS device. Is there a compatibility issue with Android 9? Are there any specific settings or updates I need to make it work?
We apologize for the inconvenience! The TNAS mobile 3 application requires a minimum system requirement of Android 10. If your phone supports an upgrade to Android 10 or a later version, please try updating the system. If not, we recommend using another phone running Android 10 or higher to install and use TNAS mobile 3.
EthanBerg97
Norway
Post by EthanBerg97 »
thanks, it is helpful.
King7
Post by King7 »
haha....I like TNAS Mobile 3, access to my TNAS everywhere makes things simple
EthanLiu
Post by EthanLiu »
The TNAS Mobile 3 application requires Android 11 or above to install.
Peterlll06
Netherlands
Post by Peterlll06 »
Maybe the version of Android 9 is too low. I am now using Android 14 and the app runs well.
