How to Upgrade f4-424 from tos5 to tos6
Re: How to Upgrade f4-424 from tos5 to tos6
I think ssh is disabled by default on 'install' of Tos6. You will most likely have to access via GUI and check all your settings.
Ok I enabled it. Port 9222 worked. But if I want to use port 22 like in TOS5, this doesn't seem to work anymore.
After upgrading the system to TOS 6, the SSH service is turned off by default, and the default port is set to 9222. Users have the option to change the default port to 22.
