TOS 6.0.610 (X86) is Released for Update
fordrwd4ever
Netherlands
Re: TOS 6.0.610 (X86) is Released for Update
Post by fordrwd4ever »
The manual installation did work , but took really long... (almost an hour..)
Still strange that the auto update cannot extract the bz2 file
DekkaR
Iceland
Post by DekkaR »
TMRyan wrote: 15 Jan 2025, 17:47
DekkaR wrote: 15 Jan 2025, 17:19 "3. Optimized the display effect that appears on the resource monitoring page."
¿Only LOAD AVERAGE and LOAD DETAILS?
And:
- CPU??
- Memory??
- Disk I/O??
- Network I/O??
Why a partial solution and not a complete solution?
Changed the coordinate values displayed in the image to start at 0.
"3. Optimized the display effect"
Effectively, the terrible redraw effect has been corrected in the first two graphs, but not in the others. The data graph should "move," not be constantly redrawn.
TM F8 SSD: 16GB RAM. 6TB TRAID EXT4:
TOS 6.0.610: Plex Server 1.41.1.9057: qBitTorrent 4.1.13: Bot.Torrent 4.0:
TM F8 SSD Plus: 32GB RAM. 4TB RAID0 EXT4:
TOS 6.0.531: MariaDB 10.3.29: phpMyAdmin 5.1.22:
[ DekkaR ]
rfbjr
Post by rfbjr »
So far so good on F2/F4-223. LUNs working and file shares. More testing continues later. (after more coffee)
F4-424 Pro also at 7.0.0777
D4-320
CraftyClown
Post by CraftyClown »
fordrwd4ever wrote: 15 Jan 2025, 18:56 The manual installation did work , but took really long... (almost an hour..)
Can I ask where you found a version to manually download?
fordrwd4ever
Netherlands
CraftyClown wrote: 15 Jan 2025, 19:52
After teh automatsc download ,you can find it in the root of your data drive , in my case it was in /Volume2/.(long name with random characters)
Unpacked it with 7-zip , then extracted it again (its a tar file) to a temp folder.
In the temp folder , just run ./install and wait for a really long time....
TMlinda
Post by TMlinda »
fordrwd4ever wrote: 15 Jan 2025, 17:58
Are you updating via SSH connection terminal? If so, it may cause the installation to be interrupted. It is recommended that you perform the update operation on the TOS system page.
fordrwd4ever
Netherlands
No , i did it via the Terminal app, as via the gui it just isn't working at all.
It looks like the archive is just not packed properly.
CraftyClown
fordrwd4ever wrote: 15 Jan 2025, 21:04
Thanks, I'll give that a try
Bartman
Post by Bartman »
CraftyClown wrote: 15 Jan 2025, 18:13 also can I get a manual download of this for one of my devices? I have an issue with the WAN not working on my F4-423 that I'm hoping will be fixed with this release
viewtopic.php?p=42325#p42325
Have you tried this page, it sorted me out with no WAN viewtopic.php?t=5939
Regards
F2-423
TOS 7.0.0777 (X86)
Bartman
Post by Bartman »
For me, the mobile app dials, heat, load, CPU, Memory and fan stats have stopped working, this happened before with an update, then got fixed with the next, so I take it we will have to wait for the next update to either fix or break it again.
Regards
F2-423
TOS 7.0.0777 (X86)
