'df', 'du' and 'stat' should all be available under Linux (ssh to command line or use terminal if you are using Tos6.1.530>)
Way to analyze drive space usage?
Re: Way to analyze drive space usage?
10TB is entirely different
Frustrated Beta Tester!!!
Have you ever used the TerraSync app? It keeps track of file versions and uses additional space for it.
ok, so using the du tool, the excessive drive space is being tied up in:
/Volume1/@sysSnapShoot/SystemSnapShot
what's odd is, the usage reported by DU in that folder is larger than my total available drive space. (the folders are blue? compressed?)
There is a utility on the TNAS web interface called Snapshot, but it doesn't appear to be installed... I may have played with it in the past.
because I'm not a linux guy, and I don't want to do something stupid, what's the best way to proceed? just delete these folders from the linux interface?
(some kind of rm -r *, i assume?)
