Execution command not editible in docker manager
Discussion about Docker
bugacha
Algeria
Re: Execution command not editible in docker manager
Post by bugacha »
tommi2day wrote: 12 Nov 2024, 04:52 You may consider to use a docker-compose.yml (a project) style configuration. For minio mine looks like this. Variables may be set this way or using env-file
How do you run it then? Manually from ssh? I assume it won't be visible in Docker Engine UI ?
tommi2day
Germany
Post by tommi2day »
OK, this one was created on the share and started via ssh, but its also visible in the docker manager
main: T9-450
bugacha
Algeria
Post by bugacha »
tommi2day wrote: 14 Nov 2024, 03:04 OK, this one was created on the share and started via ssh, but its also visible in the docker manager
got it, thanks !
bugacha
Algeria
Post by bugacha »
TMzethar wrote: 10 Nov 2024, 18:50 The implementation of your request in the UI is not currently supported and the project team will discuss ways to improve it.
I guess ignore this request, using docker compose as suggested in the thread is much cleaner and more flexible solution
Return to “Docker”
