Seagate New Drives Noises Pulsing
blutuna
Re: Seagate New Drives Noises Pulsing
Post by blutuna »
TMzethar wrote: 13 Sep 2024, 17:18 Sounds normal. Like said above, you can do comparison tests.
Or you can try to contact the supplier of the HDD to confirm.
Are there any abnormalities in daily reading and writing?
I sent the drives back after Seagate told me the sounds are not normal.
blutuna
Post by blutuna »
TMroy wrote: 13 Sep 2024, 18:23 From the sound, it seems like the hard drive is busy. Could you please tell me which slots you installed these two drives in? Have you set up any RAID configurations? Are there any applications on your computer that are reading from USB devices?
I tried the drives in all four slots, same pounding/pulsing sounds.
The D8 is is set on Single.
Was going to use the drives for video, audio storage with jellyfin and eventually a NAS.
The other 2 8GB Seagate drives do not make the sounds the 12GB drives did, they are relatively quiet (I've transferred about 6TBs in video files to those 2 drives in the D8). I have 2 more of the 12GB drives coming from Bestbuy this time and will try again when they arrive tomorrow.
blutuna wrote: 13 Sep 2024, 17:06
TMzethar wrote: 13 Sep 2024, 15:25 Your share is not accessible.
Try here... https://drive.proton.me/urls/5SBHSSDJ3W#NsUYR811QDoM
I had a listen. Sounds more like a low speed, ship, diesel engine rather than a 5400rpm drive.
blutuna
Post by blutuna »
Got the 2 new 12TB Seagate IronWolf drives yesterday and pretty the same noises at idle.... https://drive.proton.me/urls/HH85V3XA7R#GZ0Lm5JjOPtM
Here's the 2 8TB drives noises at idle.... https://drive.proton.me/urls/TXHGX09J20#LHMwKUh4z3OX
I'm not understanding why the 12TB drives (this makes 6 of them now) are making these noises when the 8TB drives don't?
blutuna
Post by blutuna »
Sent all 6 of the 12TB Seagate drives back and had a 18TB Toshiba drive delivered today, no noises at idle, quiet as the 8TB Seagate drives.
blutuna wrote: 17 Sep 2024, 07:43
Do you happen to have the model no(s) of the 'noisy' segate 12MB drives for reference?
blutuna
Post by blutuna »
Bought 6 drives, 4 from Amazon, 2 from Best Buy, all the same model...
Seagate IronWolf 12TB NAS Internal Hard Drive HDD – 3.5 Inch SATA 6Gb/s 7200 RPM 256MB Cache for RAID Network Attached Storage – Model: ST12000VN0008
fanquestions
Poland
Post by fanquestions »
It's common to have same model of HDDs but different sizes to sound differently. It's just another hassle to deal with while purchasing HDDs these days. You simply need to do a proper research.. Do reddit / NAS focused websites with YT tests :)
blutuna
Post by blutuna »
fanquestions wrote: 18 Sep 2024, 17:52 You simply need to do a proper research.. Do reddit / NAS focused websites with YT tests :)
Well, when the drives manufacturer says the noises aren't normal then I'm done "researching" and moving on to plan B :)
Fusepack01
Post by Fusepack01 »
I bought a new f4-424 pro and put in two seagate st10000vn000 - 3ak101 10TB drives (on the recommended list)- Worked fine.
I then told the system to never power down the drives.
It started making awful noises and using high cpu and slowly became more and more unstable not showing any hard drive storage pool or volume data.
turning the HD power off setting back to 30 mins and the system was happy again.
Anyone else ?
Return to “USB Series”
