TOS6 stopped fan
Re: TOS6 stopped fan
abs1ck wrote: ↑04 Jul 2024, 15:45
The high CPU temperature occurred when the fan stopped, reaching 85 degrees Celsius. When the fan is running at medium speed, the temperature is around 45-46 degrees Celsius. At high fan speed, the CPU temperature is 42-44 degrees Celsius. Are these normal values?
It's looks good. So the only problem now is that the fan does not automatically adjust its speed.
Sorry, but perhaps you can consider temporarily setting it to a fixed speed and keep an eye on future TOS updates.
Return to “System Update”
