File Manager - No Space available  [Accepted]
Already accepted requirements or suggestions.
koalakoala
Australia
Re: File Manager - No Space available
Post by koalakoala »
there is no repair function in my terramaster
We have checked your system report and found signs of frequent unplugging of disks as volumes, which may cause storage configuration confusion. Additionally, one of your disks (HDD2) is a 2GB system partition from TOS4, and smaller system partitions may encounter some issues when using TOS5.
We suggest that you try reinstalling TOS 5.1.67 or earlier versions to fix the issue of chaotic storage configuration. (If prompted to 'delete data' during installation, please stop the operation and schedule an assistance time with the technical support email.)
After completing the reinstallation, make a backup of your HDD2 data and then try to clean up the partition of HDD2.
Finally, reinstall the latest TOS.
koalakoala
Australia
Thanks for your reply TMzethar, will coordinate the online assistance.
Last time I did this I lost a HDD full of irrelevant content. This time Volume 2 is full of work files.
Thanks again.
koalakoala
Australia
Thanks Terramaster. Organised an online session withg Tech Support and now in recovery mode (it will take a few hours), but I can see some of the files :).
Thanks again!! Awesome support. Cheers
Return to “Accepted”
