When you plug the new Intit Boot USB into the USB port, then you can start the TNAS normally.
When you finish the TOS installation, please remove and save it for possible future use.
Can it be plugged into any USB port on the 424 series or does it need to be installed to an internal port like the older models?
Plugged it the usb adapter to the TNAS. TNAS.local page just refreshes but doesn’t load up. TNAS PC still doesn’t recognize device.
You can refer to this link for troubleshooting: viewtopic.php?t=2250
Sorry, but that doesn't answer the question(s).
USB Intitboot can be inserted both internally and externally, but it is recommended to insert it internally as it will not occupy the external USB interface.
