ok follow on
ok it started to restore the data the it appears it was doing a TFSS restore a snapshot of the file system.
Unsure how I managed but still it wiped all 15 usb hard drives 216tb with no warning it was going to do this
upon clicking on the nas from windows it still showed 130tb with 30tb spare and files started to appear as they once was but then when I checked 4 hrs later there was about 10tb restored but my hard drive space had dropped from 98gb used to 108tb used and only 22gb spare
at this rate it would run out of space before it could be all be restored I could not cancel it or get the system to reboot so I pulled the plug and got it to restart as I seen another post where the same thing happened and after a few days it was just restoring 0bytes because the drive was used right up and put it into a read only state
so where do I go from here it showing it took a snapshot just before the restore and usb disks wiped
do I have to do this restore in kk pic attached or do I leave the usb unplugged ??
do I need to wipe somehow volume 1 so I get the space back for the restore to have enough space ?? or what ?? have no ideas if I can just get the files back that are probably still there
I know when I first got the nas I ran into probl,ems and had to run a contisity test or something or a file fix or something where it had to check all the files and then after a week it finished and all the files was back
