Unable to complete backup
Time machine backup for macOS users
krdian
Re: Unable to complete backup
Post by krdian »
hodaka wrote: ↑20 Oct 2024, 04:51
Hi hodaka,
Seems that upgrade MacOS to Sequoia 15.1 resolved my issue, have you tried it as well ?
We will try to verify if there is a difference in the performance of Time Backup on different macOS.
hodaka
Post by hodaka »
krdian wrote: ↑29 Oct 2024, 16:09
Hi hodaka,
Has not resolved my issue. I will try to re-do setup when I have time, just in case there is an issue with my config.
FWIW, I have set up several Synology units, including one as a network TM backup for 6 Mac on various OS's, and have a strong IT background, including Windows, Mac, Linux, iOS, etc. (20 yrs working in IT). I feel I may be missing something, and will go back to the setup documentation. Maybe it has been updated with some tidbit? I know I tend to jump to a slightly more advanced config, with multiple users at different permission levels, as well as quotas and such - maybe I need to pretend I know nothing and just follow the steps?
Currently direct cable connected to my M1 iMac. Oh yah - Time Capsule is still ticking along...
sim667
Post by sim667 »
Same issue with me on MacOS sequoia, was initially able to start backups and they would then fail, and now Time Machine says the disk is not mounted when it is mounted so won't backup at all.
GodefroydeMaupeou
France
Post by GodefroydeMaupeou »
I have the same problem with the TOS 6 on a D12 500 Pro with 288 TB and Séquoia latest version.
Time Machine copies and stops at 15.95 TB showing that there is not enough space to continue while indicating the actual available space (see screenshot).
I tried all the possible configurations: with defined and indefinite quota, without quota, other folder... the result is systematically the same.
GodefroydeMaupeou wrote: ↑25 Apr 2025, 15:53
Are you referring to the T12-500 Pro?
Your issue may not be identical to the original poster's problem.
The technical support team appears to have been communicating with you via email. They will assist you in troubleshooting the issue.
GodefroydeMaupeou
France
Yes it's a T12 and I am in contact with the technical support team.
Return to “Time Machine”
