Unable to create Duple backup task
Duple Backup has powerful backup and restore functions, and is a disaster recovery tool designed to strengthen the data security of TNAS devices.
sim667
Re: Unable to create Duple backup task
Post by sim667 »
I've sent you the log
Received, analyzing.
sim667
Post by sim667 »
Is there any news on this?
Hello, based on the current information analysis, it is preliminarily determined that the problem may be that there is no permission to write to the destination folder.
Please check the permissions of the destination folder or replace the connected account with an administrator account.
Also, please try to troubleshoot network issues.
sim667
Post by sim667 »
Any idea why mega isn't working too?
Can I clarify is the mega setting on there for mega.io?
sim667
Post by sim667 »
Also a note regarding the webdav, it does create a folder on there that contains a folder with .duple at the end of the name and two subfolders contained in there called config and data. Im unable to change permissions for the folder. The provider is called livedrive.
sim667
Post by sim667 »
Mega has actually just started working. I’ve also discovered that cloud sync is better for what I need (just keeping straight backups of all my media on the drive). So I’ll probably end up just switching my cloud backups to mega
What did you do? why mega start working now?
Return to “Duple Backup”
