Can't command "hptraidconf.exe" in one line
Utileguy
Re: Can't command "hptraidconf.exe" in one line
Post by Utileguy »
Notice there was no solution for this topic. Here's the syntax that I was able to test and it works: Syntax:
hptraidconf -u {username} -p {password} {CLI command }
If the username and password is still default and you want to query the device, here a sample:
Enter ‘hptraidconf -u RAID -p hpt query devices’
You can also run this command for help: Enter ‘hptraidconf -u RAID -p hpt help’
Hope this helps for everyone who has the similar issue.
Cheers!
To7
Post by To7 »
Hello Utileguy
Thanks for your help :geek:
II try your tips soon, and say to you my result
Because i'm not behind my DAS for the moment
