I think you might be on to something, I wonder if my device shipped with a bad stick of RAM considering it has been crashing randomly since I got it, no matter the TOS version.DiscoSi wrote: ↑20 Jul 2020, 21:21 This is a bit of a long shot, but try removing the ram upgrade in one of them if you can and see if that makes any difference. I only suggest this as I believe the developers have changed some of the code that calculates available RAM and just maybe this is causing an issue in your setup? I had issues with my F5-221 reporting a negative value in the total available RAM, I had an 8GB memory stick installed on top of the onboard 2GB but the web interface reported a negative ram value! I've put a 4GB stick in now and all seems to be ok for the moment. I haven't tested the 8GB stick since 4.1.28 was released so maybe it's fixed there. Could be worth you upgrading to 4.1.28 as well?
The one time I've been able to see it log when crashing I did see memory-related errors: https://dpaste.com/GU8UGJ8MF
swapper/0: page allocation failure: order:0, mode:0x1080020(GFP_ATOMIC), nodemask=(null)
