U4-111 TOS 5.1.33 No Resources
Re: U4-111 TOS 5.1.33 No Resources
It's strange, we haven't found similar problems, we will continue to pay attention. You can try to remove the battery, use a wire to connect the two ends of the battery holder and short-circuit it for 10 seconds to clear the CMOS.
You can also send your BIOS version to the technical support email, and we can try to provide you with a new BIOS.
Binary100100
Post by Binary100100 »
{L_BUTTON_AT}Binary100100
TMzethar wrote: ↑08 May 2023, 19:30 After updating from TOS4 to TOS5, some webpage caches may affect the display, please try to clear the browser cache.Can you provide us with a screenshot of your latest description?
I just used a computer that I have NEVER logged on before and this is exactly what I see when I check the resource monitor.
bladetsa
Post by bladetsa »
I have a new T6-423, and I'm also having problems with resource monitor.
I first installed the system on a Seagate Exos 18TB but after inserting 2 nvme drives (Crucial P3 1TB)(one for system and one for cache) and reinstalling TOS 5 resource monitor stopped working.
Is there any way around this problem ?
Binary100100
bladetsa wrote: ↑08 Jun 2023, 10:41 I have a new T6-423, and I'm also having problems with resource monitor.
I haven't found a solution yet either. I'm just going to migrate the data off of it and build a Proxmox server.
Anyone can allow us to have a remote session to check this issue? as it can be reproduced in our lab.
Binary100100
TMroy wrote: ↑08 Jun 2023, 19:11 Anyone can allow us to have a remote session to check this issue? as it can be reproduced in our lab.
I'll allow you to do this.
I'm not using it anymore anyway.
Binary100100 wrote: ↑09 Jun 2023, 20:51
So would you write an email to the support team and book a remote session with them? please find the email from my signatue.
Return to “System Resources”
