Docker Compose missing dependancy?
Re: Docker Compose missing dependancy?
After do the steps mentioned
docker-compose --version
Traceback (most recent call last):
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/setuptools-63.2.0-py3.10.egg/pkg_resources/__init__.py", line 581, in _build_master
ws.require(__requires__)
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/setuptools-63.2.0-py3.10.egg/pkg_resources/__init__.py", line 909, in require
needed = self.resolve(parse_requirements(requirements))
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/setuptools-63.2.0-py3.10.egg/pkg_resources/__init__.py", line 800, in resolve
raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.VersionConflict: (docker-compose 1.29.2 (/Volume1/@apps/Python3/lib/python3.10/site-packages), Requirement.parse('docker-compose==1.24.1'))
During handling of the above exception, another exception occurred:
File "/usr/bin/docker-compose", line 6, in <module>
from pkg_resources import load_entry_point
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/setuptools-63.2.0-py3.10.egg/pkg_resources/__init__.py", line 3260, in <module>
def _initialize_master_working_set():
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/setuptools-63.2.0-py3.10.egg/pkg_resources/__init__.py", line 3234, in _call_aside
f(*args, **kwargs)
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/setuptools-63.2.0-py3.10.egg/pkg_resources/__init__.py", line 3272, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/setuptools-63.2.0-py3.10.egg/pkg_resources/__init__.py", line 583, in _build_master
return cls._build_from_requirements(__requires__)
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/setuptools-63.2.0-py3.10.egg/pkg_resources/__init__.py", line 596, in _build_from_requirements
dists = ws.resolve(reqs, Environment())
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/setuptools-63.2.0-py3.10.egg/pkg_resources/__init__.py", line 795, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'docker-compose==1.24.1' distribution was not found and is required by the application
and even installing the "correct" verison with ./pip install docker-compose==1.24.1
It doesnt work
docker-compose up -d
File "/usr/bin/docker-compose", line 11, in <module>
load_entry_point('docker-compose==1.24.1', 'console_scripts', 'docker-compose')()
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/compose/cli/main.py", line 71, in main
command()
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/compose/cli/main.py", line 124, in perform_command
project = project_from_options('.', options)
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/compose/cli/command.py", line 33, in project_from_options
return get_project(
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/compose/cli/command.py", line 111, in get_project
config_details = config.find(project_dir, config_path, environment, override_dir)
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/compose/config/config.py", line 291, in find
[ConfigFile.from_filename(f) for f in filenames],
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/compose/config/config.py", line 291, in <listcomp>
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/compose/config/config.py", line 191, in from_filename
return cls(filename, load_yaml(filename))
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/compose/config/config.py", line 1493, in load_yaml
return yaml.safe_load(fh)
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/yaml/__init__.py", line 94, in safe_load
return load(stream, SafeLoader)
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/yaml/__init__.py", line 72, in load
return loader.get_single_data()
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/yaml/constructor.py", line 37, in get_single_data
return self.construct_document(node)
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/yaml/constructor.py", line 46, in construct_document
for dummy in generator:
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/yaml/constructor.py", line 398, in construct_yaml_map
value = self.construct_mapping(node)
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/yaml/constructor.py", line 204, in construct_mapping
return super().construct_mapping(node, deep=deep)
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/yaml/constructor.py", line 126, in construct_mapping
if not isinstance(key, collections.Hashable):
AttributeError: module 'collections' has no attribute 'Hashable'
I revert back as mentioned
python -> /Volume1/@apps/Python3/sysroot/usr/bin/python
the python default to python2.7
cd /usr/bin/
unlink python
ln -s python2.7 python
docker-compose installed location
whereis docker-compose
docker-compose: /usr/bin/docker-compose /Volume1/@apps/docker/dockerd/bin/docker-compose
maybe this need to be changed
#!/usr/bin/python
# EASY-INSTALL-ENTRY-SCRIPT: 'docker-compose==1.24.1','console_scripts','docker-compose'
import re
import sys
# for compatibility with easy_install; see #2198
__requires__ = 'docker-compose==1.24.1'
try:
from importlib.metadata import distribution
except ImportError:
try:
from importlib_metadata import distribution
except ImportError:
def importlib_load_entry_point(spec, group, name):
dist_name, _, _ = spec.partition('==')
matches = (
entry_point
for entry_point in distribution(dist_name).entry_points
if entry_point.group == group and entry_point.name == name
return next(matches).load()
globals().setdefault('load_entry_point', importlib_load_entry_point)
if __name__ == '__main__':
sys.argv[0] = re.sub(r'(-script\.pyw?|\.exe)?$', '', sys.argv[0])
sys.exit(load_entry_point('docker-compose==1.24.1', 'console_scripts', 'docker-compose')())
Let me know if you need something more ...
f(*args, **kwargs)
It doesnt work
command()
return get_project(
cd /usr/bin/
unlink python
#!/usr/bin/python
import re
import sys
try:
except ImportError:
try:
except ImportError:
matches = (
entry_point
TOS 5.0.171 (x.86)
F5-221 - 10G - 4x4TB (WD Red Pro) - raid5 (btrfs)
Docker containers with docker-compose, managed with portainer
TOS 5.0.171 (x.86)
Did you install setuptools?
install python
cd /setuptools-63.2.0
python setup.py build
python setup.py install Code: Select all
./pip install docker-compose or pip install docker-compose To contact our team, please send email to following addresses, remember to replace (at) with @:
We are not on the same page.
Is docker manager who install the docker-compose, and it ask for docker-compose 1.24.1
Even if i can install other it gives the error,
So i think you are not understanding the dependencies needed, can you dig more please ?
TOS 5.0.171 (x.86)
TOS 5.0.171 (x.86)
{L_BUTTON_AT}rpluto
TMSupport wrote: ↑21 Oct 2022, 18:09 Please do the following. 1. Go to the application center to install Python3 and then install pip. 2. Login to the SSH terminal and execute the following command.Code: Select all
cd /Volume1/@apps/Python3/sysroot/usr/binCode: Select all
-bash: ./pip: No such file or directoryCode: Select all
./pip3 install docker-compose
Collecting docker-compose
Downloading docker_compose-1.29.2-py2.py3-none-any.whl (114 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 114.8/114.8 kB 660.1 kB/s eta 0:00:00
Requirement already satisfied: requests<3,>=2.20.0 in /Volume1/@apps/Python3/lib/python3.10/site-packages (from docker-compose) (2.28.1)
Collecting docopt<1,>=0.6.1
Downloading docopt-0.6.2.tar.gz (25 kB)
Preparing metadata (setup.py) ... done
Collecting PyYAML<6,>=3.10
Downloading PyYAML-5.4.1.tar.gz (175 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 175.1/175.1 kB 1.7 MB/s eta 0:00:00
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... error
error: subprocess-exited-with-error
× Preparing metadata (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [63 lines of output]
/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/config/setupcfg.py:508: SetuptoolsDeprecationWarning: The license_file parameter is deprecated, use license_f iles instead.
warnings.warn(msg, warning_class)
running dist_info
creating /tmp/pip-modern-metadata-6miqkhtd/PyYAML.egg-info
writing /tmp/pip-modern-metadata-6miqkhtd/PyYAML.egg-info/PKG-INFO
writing dependency_links to /tmp/pip-modern-metadata-6miqkhtd/PyYAML.egg-info/dependency_links.txt
writing top-level names to /tmp/pip-modern-metadata-6miqkhtd/PyYAML.egg-info/top_level.txt
writing manifest file '/tmp/pip-modern-metadata-6miqkhtd/PyYAML.egg-info/SOURCES.txt'
skipping 'yaml/_yaml.c' Cython extension (up-to-date)
reading manifest file '/tmp/pip-modern-metadata-6miqkhtd/PyYAML.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
adding license file 'LICENSE'
creating '/tmp/pip-modern-metadata-6miqkhtd/PyYAML-5.4.1.dist-info'
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/pip/_vendor/pep517/in_process/_in_process.py", line 363, in <module>
main()
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/pip/_vendor/pep517/in_process/_in_process.py", line 345, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/site-packages/pip/_vendor/pep517/in_process/_in_process.py", line 164, in prepare_metadata_for_build_wheel
return hook(metadata_directory, config_settings)
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 377, in prepare_metadata_for_build_wheel
self.run_setup()
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 335, in run_setup
exec(code, locals())
File "<string>", line 271, in <module>
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/__init__.py", line 87, in setup
return distutils.core.setup(**attrs)
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 968, in run_commands
self.run_command(cmd)
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/dist.py", line 1217, in run_command
super().run_command(command)
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 987, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/command/dist_info.py", line 101, in run
bdist_wheel = self.get_finalized_command('bdist_wheel')
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/_distutils/cmd.py", line 305, in get_finalized_command
cmd_obj = self.distribution.get_command_obj(command, create)
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 859, in get_command_obj
klass = self.get_command_class(command)
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/setuptools/dist.py", line 954, in get_command_class
self.cmdclass[command] = cmdclass = ep.load()
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/importlib/metadata/__init__.py", line 171, in load
module = import_module(match.group('module'))
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/wheel/bdist_wheel.py", line 26, in <module>
from .macosx_libfile import calculate_macosx_platform_tag
File "/tmp/pip-build-env-sijjwy1k/overlay/lib/python3.10/site-packages/wheel/macosx_libfile.py", line 41, in <module>
import ctypes
File "/Volume1/@apps/Python3/sysroot/usr/lib/python3.10/ctypes/__init__.py", line 8, in <module>
from _ctypes import Union, Structure, Array
ImportError: libffi.so.8: cannot open shared object file: No such file or directory
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
{L_BUTTON_AT}rpluto
I have just download normal version of docker-compose)
$ curl -L https://github.com/docker/compose/releases/download/1.24.1/docker-compose-`uname -s`-`uname -m` -o /Volume1/@apps/docker/dockerd/bin/docker-compose
$ chmod +x /Volume1/@apps/docker/dockerd/bin/docker-composeRe: Docker Compose missing dependancy?
@Terramaster- Is there an ETA on a fix for this within the app?
{L_BUTTON_AT}matt_30
./pip install docker-composeTo contact our team, please send email to following addresses, remember to replace (at) with @
{L_BUTTON_AT}XFNeo
If you encounter the above prompt, it may be that you have not installed the pip application or the pip application was installed before Python3.
Please install pip again in the app center.
{L_BUTTON_AT}XFNeo
Using cached docker_compose-1.29.2-py2.py3-none-any.whl (114 kB)
Using cached docopt-0.6.2.tar.gz (25 kB)
Collecting docker[ssh]>=5
Downloading docker-6.0.0-py3-none-any.whl (147 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 147.2/147.2 kB 812.0 kB/s eta 0:00:00
Collecting python-dotenv<1,>=0.13.0
Downloading python_dotenv-0.21.0-py3-none-any.whl (18 kB)
Collecting dockerpty<1,>=0.4.1
Downloading dockerpty-0.4.1.tar.gz (13 kB)
Collecting distro<2,>=1.5.0
Downloading distro-1.8.0-py3-none-any.whl (20 kB)
Collecting websocket-client<1,>=0.32.0
Downloading websocket_client-0.59.0-py2.py3-none-any.whl (67 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 67.2/67.2 kB 4.4 MB/s eta 0:00:00
Using cached PyYAML-5.4.1.tar.gz (175 kB)
│ exit code: 1
/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/config/setupcfg.py:508: SetuptoolsDeprecationWarning: The license_file parameter is deprecated, use license_files instead.
running dist_info
creating /tmp/pip-modern-metadata-1fzd1_yp/PyYAML.egg-info
writing /tmp/pip-modern-metadata-1fzd1_yp/PyYAML.egg-info/PKG-INFO
writing dependency_links to /tmp/pip-modern-metadata-1fzd1_yp/PyYAML.egg-info/dependency_links.txt
writing top-level names to /tmp/pip-modern-metadata-1fzd1_yp/PyYAML.egg-info/top_level.txt
writing manifest file '/tmp/pip-modern-metadata-1fzd1_yp/PyYAML.egg-info/SOURCES.txt'
reading manifest file '/tmp/pip-modern-metadata-1fzd1_yp/PyYAML.egg-info/SOURCES.txt'
creating '/tmp/pip-modern-metadata-1fzd1_yp/PyYAML-5.4.1.dist-info'
main()
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 377, in prepare_metadata_for_build_wheel
self.run_setup()
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 335, in run_setup
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/__init__.py", line 87, in setup
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 185, in setup
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 968, in run_commands
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/dist.py", line 1217, in run_command
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 987, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/command/dist_info.py", line 101, in run
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/_distutils/cmd.py", line 305, in get_finalized_command
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 859, in get_command_obj
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/setuptools/dist.py", line 954, in get_command_class
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/wheel/bdist_wheel.py", line 26, in <module>
File "/tmp/pip-build-env-vp6i6419/overlay/lib/python3.10/site-packages/wheel/macosx_libfile.py", line 41, in <module>
import ctypes
[end of output]
hint: See above for details.Re: Docker Compose missing dependancy?
Apologies for the delay in responding.
I receive the same results as @SFNEO. However, so there is no confusion. The question was will this be fixed in the app?
I have put a dirty walk around in place, however I have no idea if this will present more errors in the future.
Engagement for fault resolution of this problem seamed to go quiet as soon as workarounds were presented.
Option B would be to enable software repo commands like Yum so we can just pull this ourselves.
