TOS 5.0.158 (x.86) is Released for Update
MisterXY
Germany
Re: TOS 5.0.158 (x.86) is Released for Update
Post by MisterXY »
The S.M.A.R.T Error and the Usbshare permission error also there.
SMART issue will be fixed soon. usbshare issue is still under verification, this need to take some time.
MisterXY
Germany
Post by MisterXY »
Thank you, finally an answer and reaction to the topic of usbshare.
gretor
Post by gretor »
I update from 5.0.156 to 5.0.158 . After Update No more Access to NAS. SSH down, Webinterface down. :(
I reinstalled all....
lg gretor
gretor
Post by gretor »
Update:
To recap. I have now reinstalled everything, which is relatively fast for me because I have a corresponding recovery plan as a company admin.
Once again for the Terra Master team for information.
During the update from 1.0.156 to 1.0.158 it came to the said crash. After the upgrade, the Terra Master system was no longer accessible via SSH and the WebInferface.
I created the following prerequisites before the update:
I have the following application running:
Virtuel Box with Ubuntu Server VM
Surveillance APP
Plex Media APP.
The following I have done BEFORE the update:
VM shut down. Uninstalled Virtuel Box
Surveillance APP Disabled
Plex Media APP Disabled.
Then I patched and it came to the said incident.
Other than that, the NAS only provides SMB and encrypted share folders for the internal network.
I don't know if it is possible to reproduce this update crash. Unfortunately, I do not have the capacity to test this.
If there are further questions about the crash I am available for questions.
Lg gretor
Thank you very much for your information! We will try to verify such issue in our lab. I suspect that some services were not completely stopped before the system update, which caused some system files to be damaged.
scout71
Italy
Post by scout71 »
I had to reinstall the system because it was no longer showing me the web interface. But now through smb I see the USB disks inserted but from the TOS file explorer I don't see any USB device, not even the UPS. Before, everything worked fine. What happened?
txhousa
Post by txhousa »
I'm frustrated with constantly updates and each update causes endless problems. I almost have to reconfigure my apps every time so that they can work.
sianderson
Post by sianderson »
> work.
one solution would be to just sit on the version you are and not upgrade until they get a stable version unless theres an issue in your version that needs to be fixed urgently, in a way im glad they arent working on an ARM version just yet so us on the 210 series arent affected by all this
{L_BUTTON_AT}txhousa
Which apps are you using?
