TOS 5.0.135 (x.86) is Released for Update
gedhi
Re: TOS 5.0.135 (x.86) is Released for Update
Post by gedhi »
zimo85 wrote:
> gedhi wrote:
> > Upgraded from 5.0.130
> > No Volume and Storage Pool.
> > No /Volume2 folder into FS root
> > Same situation after restore from default.
> > Any suggestion?
> Same problem here.
> I have tried to remove one disk and, after the restart, the files magically appears.
> But then I retry to access after a few hours, and there is nothing on the disk, no
> volume, no storage pools.
Same test, same issue, same result :-)
Please @TMSupport help! ^_^
EgorA
Post by EgorA »
danielv wrote:
> The process is thumbnailDaemon.
> I understand that is indexing the photos to make thumbnails... but almost 5
> hours at 100%?
I have the same figure - above 5 hours with disabled media indexing.
Something was broken in new firmware.
As we are not magicians, we can't help only depending on messages like "no volume, no storage pool, same test, same issues, same results".
Please provide more information as the article mentioned.
zimo85
Italy
Post by zimo85 »
TNAS F2-220
TOS 5.0.135-00173
HDD 2x WDC WD10EARX-00N0YB0 in RAID 1 configuration
After update from previuos version, all files disappeared from File Manager.
In Control Panel, there are no Volumes and no Storage Pools. The HDDs are recognized well.
App Center->Installed: empty list (I had installed Plex, Cloud Sync, VPN Server and USB Copy)
I have tried to do a factory reset, but nothing changed.
I removed one disk and restarted the system, then all the files reappeared, with the notification of an issue with the RAID (obviously).
I have reinserted the disk and, again, every file disappeared.
So, I have tried to attach one HDD to my Windows 11 pc with a SATA-to-USB converter, mounted it on WSL2 and all my files are still there!
I don't know why TOS does not recognize anymore the correct volume.
The update was made by control panel, "automatic" way.
Please power off your tnas, insert your two drives, and power on your tnas again. Then download the sys log and email it to our tech team, thank you!
elite5211
Post by elite5211 »
i have the same problem no shares. also if i try to add a application says not found
(The following text is added by TerraMaster support team)
Such a report is totally no help! Issues are not clear, and no helpful information is provided.
{L_BUTTON_AT}zimo85
if you are not able to see your volumes and storage pools from the control panel after tnas restart, it may be because the system is slow to respond, please try to refresh the web browser.
zimo85
Italy
Post by zimo85 »
{L_BUTTON_AT}zimo85
[quote=TMroy post_id=19927 time=1658159185 user_id=1656]
[/quote]
No, i cannot see it even after hours. The resource monitor says that the system is "fresh", cpu around 3% and memory around 17%.
[quote=TMroy post_id=19924 time=1658156673 user_id=1656]
[/quote]
The logs in Control Panel -> System logs are empty.
Now I am trying to send to support mail address the report generated by Technical Support -> Report Issues
Did you refresh your web browser? web browser, not TOS.
zimo85
Italy
Post by zimo85 »
Sure, I have also tried with another browser and another pc. The issue is not related to browser, cache, or something like that.
I have just sent a mail to support with the big report
