[ HomeAssistant ] Open source home automation
TheOpsMgr
Re: [ HomeAssistant ] [ 2022.6.5 ] Open source home automation
Post by TheOpsMgr »
Note that it's pretty straightforward to get home-assistant running via Docker on TNAS. I'm on TOS 5 F4-423.
Broadly speaking you can follow the instructions from here - https://www.home-assistant.io/installation/alternative/
1 - Install the Docker Manager from the App Center
2 - In the Registry tab search for homeassistant/home-assistant
3 - Download the HomeAssistant docker Image to your NAS (click the download button, top right)
4 - Run the Docker image
5 - you will have to map a volume for the Docker data, and make sure you bridge the network to the host
6 - Once it's running you can access the web page via <yourNASIP>:<Port> (8123 in my example)
Re: [ HomeAssistant ] Open source home automation
up to 2022.11.1 and added TOS5 version
user222333
Post by user222333 »
please, help!
Module WebUI HomeAssistant http://IP:8123 does not open
what needs to be done?
модель F2-221
TOS version 5.0.176-00227
python3.10 was added to PATH
installed version is 3.10.5.0
Autostart on boot is Enabled
tpk HomeAssistant TOS5 2022.11.1.0 x86_64.tpk installed with administrator account
HomeAssistant (pid XXXXX) is running
installed version is 2022.11.1.0
home-assistant.log:
<br />
<b>Warning</b>: fopen(/home/homeassistant/home-assistant.log): failed to open stream: No such file or directory in <b>/Volume1/@apps/HomeAssistant/webui/6.php</b> on line <b>86</b><br />
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
download again the appand install it, i've made some changes
user222333
Thanks it works!!!
paolodagostino
Post by paolodagostino »
I have the same problem of user222333 but with the tnas 4.x version... :cry:
anyway to solve the problem?
user222333
{L_BUTTON_AT}duberic
outkastm wrote: ↑07 Aug 2022, 14:14 What add-ons do you need? Will be done as separate tpk files.
Hello Outkastm! Is it possible to install HACS (Home Assistant Community Store)?
lsalvador
Post by lsalvador »
Hi, i can't enable home Assistent
I received "Operation failed". Any ideia?
mokagino
Israel
Post by mokagino »
Hey,
Are there any plans to update Home Assistant to newer version?
Thanks!
up to 2023.4.6.2
