TOS 4.2.28(ARM) is released for update
crisisacting
Re: TOS 4.2.28(ARM) is released for update!
Post by crisisacting »
vincentld wrote: ↑28 Jan 2022, 05:05 Hello,
please, could you provide download link for manual update ?
Thanks,
https://support.terra-master.com/downlo ... uct=F2-210
https://support.terra-master.com/downlo ... uct=F4-210
Southland
Post by Southland »
I am having a problem with this release using rsync. My main unit is a F4-210 and I use rsync to back up to a F2-210 and a Synology nas. This has been working for 1.5 years. The backups to the Synology works fine, but I get an error on the F4-210 unit in the Backup/rsync app when backing up to the F2-210 unit. The username and password are both good. I do not believe I was getting this error with the previous release. Both the F4-210 and F2-210 are running TOS 4.2.28 release. Has anyone else seen a problem with rsync in this release?
Connection failed! The following error message was returned by the system:
2022/02/05 23:13:13 [5452] @ERROR: auth failed on module
2022/02/02 23:13:13 [5452] rsync error: error starting client-server protocol (code 5) at main.c(1648) [Receiver=3.1.2]
It seems the rsync service failed to start, Try to restart your F2-210 and try again.
Southland
Post by Southland »
I've restarted both devices multiple times but it did not fix the problem. I receive the same error.
You can try to reset the username and password of the rsync server, authorized folders, etc.
