[ ttyd] Share your terminal over the web
Re: [ ttyd] Share your terminal over the web
Not all, just the ones that need the binary to be available in path. This is done on the app level and is now available automatically in ttyd when is the case.
neoz
Andorra
Post by neoz »
Hi!
Firstly, sorry, I'm new on it.
I have a F-424 Pro and have installed the 1.7.4.1 x86_64 ttyd appilcation version. It was installed correctly but when I try to access it a window opens with the message:
(Access denied !) - you need to login on TOS with an admin role account
I'm logged in with a admin account.
Am I doing something wrong? Can you help me?
Thank you!!
F4-424 Pro - TOS 6
this app is not ready for TOS6 > 6.0.420. Wait for new version with TOS6 on the filename
neoz
Andorra
Post by neoz »
outkastm wrote: ↑03 Jan 2025, 04:43
Oops! Totally true.
For some reason, I mistook TOS5 6.0.124 for TOS6. I didn’t read carefully, or maybe my eyes got crossed :-)
I’ll keep an eye out for updates!
Thank you so much for your great work!
F4-424 Pro - TOS 6
samius
Post by samius »
neoz wrote: ↑03 Jan 2025, 13:26
in the latest versions of tos6 ttyd is built into the system... maybe this will be enough for you...
F4-424 MAX TOS 7
neoz
Andorra
Post by neoz »
samius wrote: ↑03 Jan 2025, 19:11
OMG it's true @samius. I didn't know.
What I haven't seen is any option to launch it from the TOS 6 UI, configure, or something else. Only I've seen the configuration options for terminal (ssh/telnet) to enable or disable it, allow access from the same network, etc...
I have launched successfull only from a ssh connection with the command:
ttyd -t disableReconnect=true bash
I needed use the "disableReconnect" parameter because without I have a lot of
uv_read failed with error -5: i/o error
Thank you for you help
F4-424 Pro - TOS 6
samius
Post by samius »
@outkastm
Hello, inside last ttyd_okm version 1.7.7 bin file old version 1.7.4
F4-424 MAX TOS 7
sergio
Germany
Post by sergio »
Great, does it works well on Max version?
Works on any TOS version. This app will be updated soon to use different oauth2 authentication options. Now is using a basic one.
eriio
Portugal
Post by eriio »
Hi. I have instaled version 1.7.4.1 on my F2-221 ToS 5.1.145-00012. Access everything but the page gets the error "Press enter to reconnect". I press and it goes again. Can't use TTYD. Can anyone help me?
