[ Bazarr ] Subtitle companion application to Sonarr and Radarr
bhook
Re: [ Bazarr ] Subtitle companion application to Sonarr and Radarr
Post by bhook »
OK, great after installing 3.8 - it is working!
It is confusing as the "Python38 > 3.8.7.3" looks like greater than, ie. 3.11 should of worked
Is not confusing, Python311 is another app.
SlyZillaTV
Denmark
Post by SlyZillaTV »
Hi @Outkastm
Just installed Bazarr, and although it "works" it dosent with for example opensubtitles as the version of Bazarr is too old. (Bad status code: 426 opensubtitles - when I asked them they say it's because i'm running an old Bazarr version)
It's running version 1.1.0 and latest "non beta" version from Bazarr Github is 1.4.3
Could you update it? As when Bazarr auto updates via the app provided here it fails.
Or show me how to install it manually myself :=)
Regards
App will be updated asap
tatundria
Argentina
Post by tatundria »
Hi, are you planning to update Bazarr for TOS 6?
Yes, will be done
tatundria
Argentina
Post by tatundria »
Hi, any news on a TOS6 version of Bazarr? I have seen that you have just updated Radarr to latest version for TOS6, so it would be great if you we can also have Bazarr as a companion app...
Will be done
TOS6 version is available now
