[ ResilioSync ][ 2.7.3.1381.0 ] Fast, reliable, and simple file sync and share solution
alexinwonderland
Re: [ ResilioSync ][ 2.7.2.1375.0 ] Fast, reliable, and simple file sync and share solution
Post by alexinwonderland »
{L_BUTTON_AT}outkastm
HI there, I'm having the same problem. I had it working for several months, but I had to reset/reinstall the system. I followed the same instructions and the app now appears on the Desktop, but I cannot access the GUI anymore.
Roccia7
Italy
Re: [ ResilioSync ][ 2.7.3.1381.0 ] Fast, reliable, and simple file sync and share solution
Post by Roccia7 »
outkastm wrote: ↑09 Apr 2022, 06:01 up to 2.7.3.1381.0
Hello outkastm, I'm trying TOS 5 and i would install some of your apps. But i receive an error that i can't install it. Maybe because of different root file system and storage mount path?
TNAS F2-220
TOS 5.0.176
TOS5 need's a new tpk packaging tool, which hasn't been made available yet by TM
EgorA
Post by EgorA »
outkastm wrote: ↑18 Apr 2022, 19:59 TOS5 need's a new tpk packaging tool, which hasn't been made available yet by TM
Ask them please!!!
F4-423
Got promises that will be available next week
mythezone
Post by mythezone »
Hello, the download link is the same as FileBrowser, can you guys fix that? Thank you.
The download link has been adapted
Roccia7
Italy
Post by Roccia7 »
Hello outkastm, is it possible to port resilio to tos5 please?
TNAS F2-220
TOS 5.0.176
scout71
Italy
Post by scout71 »
Roccia7 wrote: ↑15 Jul 2022, 12:43 Hello outkastm, is it possible to port resilio to tos5 please?
+1 :D
