[ Syncthing ] Continuous Replication/Cluster Sync
Re: [ Syncthing ][ 1.12.1.0 ]Continuous Replication/Cluster Sync
You can download again and install the app.
This message with no access, is because there were some changes in the OS since the first versions of these apps were released.
This only restrict the access to the additional settings from WebUI (manually start, stop, edit config, etc) but the app start correctly.
Re: [ Syncthing ][ 1.18.3.0 ]Continuous Replication/Cluster Sync
up to 1.18.3.0
Re: [ Syncthing ][ 1.18.4.0 ]Continuous Replication/Cluster Sync
up to 1.18.4.0
Re: [ Syncthing ][ 1.18.5.0 ]Continuous Replication/Cluster Sync
up to 1.18.5.0
Re: [ Syncthing ][ 1.18.6.0 ]Continuous Replication/Cluster Sync
up to 1.18.6.0
Re: [ Syncthing ][ 1.19.0.0 ]Continuous Replication/Cluster Sync
up to 1.19.0.0
Re: [ Syncthing ][ 1.19.1.0 ]Continuous Replication/Cluster Sync
up to 1.19.1.0
Re: [ Syncthing ][ 1.19.2.0 ]Continuous Replication/Cluster Sync
up to 1.19.2.0
Nodsert
Post by Nodsert »
outkastm wrote: ↑25 Apr 2022, 06:08 up to 1.19.2.0
The application is trying to update itself but does not have permission to write to the directory.
2022-05-03 23:36:42: upgrading: open /mnt/md0/application/SyncThing/bin/syncthing/syncthing893965879: permission denied
How can I give write permissions to the directory?
Regards.
Re: [ Syncthing ][ 1.20.1.0 ]Continuous Replication/Cluster Sync
up to 1.20.1.0
